Problems with my jail
ethereal
i previously got a mysql jail on 9.2 working with my xbmc boxes.
i got a new router linksys WRT1900AC and now the jail doesn't work - xbmc cannot see mysql
i thought it was because the address of the jail was 192.168.0.2 and the new router uses 192.168.1
i thought i would delete the jail and make a new one and hopefully this would fix the issue with the ip address
i created a new jail and it has the ip address 192.168.0.1 - does this mean it is independent of the router - is this a freenas thing or do i need a jail with the corrrect number - 192.168.1.1 ?
anyway i went in to my jail and tried to install mysql and i got an error
root@mysql:/ # pkg install mysql55-server
Updating FreeBSD repository catalogue...
pkg: http://pkg.FreeBSD.org/freebsd:9:x86:64/latest/meta.txz: No address record
pkg: repository FreeBSD has no meta file, using default settings
pkg: http://pkg.FreeBSD.org/freebsd:9:x86:64/latest/digests.txz: No address record
pkg: Unable to update repository FreeBSD
All repositories are up-to-date.
The following 2 packages will be affected (of 0 checked):
New packages to be INSTALLED:
mysql55-server: 5.5.39
mysql55-client: 5.5.39
The process will require 104 MB more space.
7 MB to be downloaded.
Proceed with this action? [y/N]: y
pkg: http://pkg.FreeBSD.org/freebsd:9:x86:64/latest/All/mysql55-server-5.5.39.txz: No address record
hopefully somebody can help me make a new jail with mysql installed - i am now running 9.3
thank you
192.168.0.* and 192.168.1.* are different networks. Your options are either to set the router to use 192.168.0.* for your LAN, or change the jails configuration (it's in the "advanced mode" section) to use 192.168.1.* IPs for the jails.
ethereal
i did try to change the jail to 192.168.1.2 but it didn't work, so i deleted it, i thought it would be easier to create a new one.
are the install errors because the original installation of freenas 9.3 was using the old router (192.168.0.1) - now i have a new router (192.168.1.1) - are there configuration files with the old address causing my install errors ?
ethereal
Okay i think i worked it out - on the jails page - configuration tab there is a whole load of ip address using the 192.168.0 - (i changed the zeros to ones)
i created a new jail and it is 192.168.1.2 and i can install mysql
ethereal
i am in my jail and i tried to edit - /etc/rc.conf and got an error
nano /etc/rc.conf
Shared object "libiconv.so.2" not found, required by "libintl.so.8"
ethereal
me again
pkg install libiconv
solved the nano problem
