kschreyack
- Dec 26, 2015
Hi Everyone,
I'm new to FreeNAS 9.3.1, however quickly coming up to speed. The current show stopper for me is presenting storage via FC Target. The card I'm working with is a Qlogic 2462. I've followed the advice here and I have the services and drivers in place that seem to be correct as per the following log output:
freenas isp1: <Qlogic ISP 2432 PCI FC-AL Adapter> port 0xd400-0xd4ff mem 0xfae3c000-0xfae3ffff irq 42 at device 0.1 on pci5
Dec 26 11:23:28 192.168.2.32 Dec 26 11:23:28 nas01 ispfw: registered firmware <isp_2400>
I have the fc adapter in target mode, as per this output (note that isp0 is not plugged in, only isp1):
[root@freenas] ~# grep isp /var/log/messages
Dec 27 09:15:48 freenas ctlfe_onoffline: SIM isp0 (path id 1) target disable succeeded
Dec 27 09:15:48 freenas ctlfe_onoffline: SIM isp1 (path id 2) target disable succeeded
Dec 27 09:15:54 freenas (ctl0:isp0:0:256:0): Target Mode not enabled yet- lun enable deferred
Dec 27 09:15:54 freenas (ctl1:isp0:0:256:1): Target Mode not enabled yet- lun enable deferred
Dec 27 09:15:54 freenas (ctl2:isp0:0:-1:-1): Target Mode not enabled yet- lun enable deferred
Dec 27 09:15:55 freenas ctlfe_onoffline: isp0 current WWNN 0x2000001b328ee2d8
Dec 27 09:15:55 freenas ctlfe_onoffline: isp0 current WWPN 0x2100001b328ee2d8
Dec 27 09:15:55 freenas ctlfe_onoffline: SIM isp0 (path id 1) target enable succeeded
Dec 27 09:15:55 freenas (ctl3:isp1:0:256:0): Target Mode not enabled yet- lun enable deferred
Dec 27 09:15:55 freenas (ctl4:isp1:0:256:1): Target Mode not enabled yet- lun enable deferred
Dec 27 09:15:55 freenas (ctl5:isp1:0:-1:-1): Target Mode not enabled yet- lun enable deferred
Dec 27 09:15:55 freenas ctlfe_onoffline: isp1 current WWNN 0x2000001b32aee2d8
Dec 27 09:15:55 freenas ctlfe_onoffline: isp1 current WWPN 0x2101001b32aee2d8
Dec 27 09:15:56 freenas ctlfe_onoffline: SIM isp1 (path id 2) target enable succeeded
The output above is a result of shutting the FC front end ports and then starting them. They are enabled as follows:
[root@freenas] ~# ctladm port -l
Port Online Frontend Name pp vp
0 YES ioctl ioctl 0 0
1 YES tpc tpc 0 0
2 NO camsim camsim 0 0 naa.5000000402496f03
3 YES camtgt isp0 0 0 naa.2100001b328ee2d8
4 YES camtgt isp1 0 0 naa.2101001b32aee2d8
5 YES iscsi iscsi 257 1 iqn.freenas.myexpertise.net.test01,t,0x0101
6 YES iscsi iscsi 257 2 iqn.freenas.myexpertise.net.test02,t,0x0101
The iscsi stuff works just fine, without any initiator not seeing them. However I have some 4GB fiber that I need to make use of, thus the importance of getting this to work.
Let me know what you think, what info you may need from me in troubleshooting the issue, etc. I thank you, for your help in advance! Have a great day :)
Klaus Schreyack
Systems Engineer
RHCE MCSE A+ Certified
1 YES tpc tpc 0 0
Klaus Schreyack
Systems Engineer
