SOLVED Problems unmounting a drive
NASbox
I imported an NTFS drive, and it seemed to import OK, but for some reason (maybe disk errors as the drive was not in good shape, or possibly something I did in the shell), the drive does not appear to have been unmounted.
The NTFS drive is still displayed on the GUI:
and I don't see any way to unmount from the GUI. I don't know if I missed something. The results of the mount command:
show the drive is still mounted.
Will I mess anything up if I just execute a simple umount command like this:
umount /var/run/importcopy/tmpdir/dev/ada4s3
from the shell?
from the shell?
Should be OK
The system isn't relying on any NTFS disks for any of the services.
NASbox
@sretalla thanks for the reply. I ran the umount, and it seemed to work OK. The drive disappeared after I physically removed the drive from the system.
