I'm trying to set up rsync to push from my PC to a FreeNAS box. So far I've set up a test directory structure:
Then I ran
Forgetting to add the trailing slash after Move2. As expected that created the directory Move2 in the destination folder, but I couldn't access it, and rsync couldn't transfer all the files:
Doing a ssh into my FreeNAS box and then "ls -al" I see:
Looks like the reason I can't access the directory is because of missing permissions, which I suspect is also the reason why rsync is throwing those "Permission denied" errors.
I've also tried the same rsync command above *with* the trailing slash. That results in
which again leaves me unable to access any of the files or directories unless I do a chmod.
So I guess the question is, what am I missing to get the right permissions set on the files? The destination rsync directory has the right permissions set (I think) but they don't seem to carry down to the contents, even though I'm running rsync as the same user who is in the same group. (And yes, the rsync module on the FreeNAS box has user: Bob and group: bobgroup.)
+---Move2
| Test 1.txt
| Test02.txt
+---Directory 1
| Testd1 1.txt
| Testd1-2.txt
\---Directory02
Testd2 1.txt
Testd2-2.txtThen I ran
rsync -iirtvv --progress ./Move2 Bob@192.168.11.155::archive
opening tcp connection to 192.168.11.155 port 873
sending daemon args: --server -vvtre.iLs "--log-format=%i%I" . archive/ (5 args)
sending incremental file list
cd+++++++++ Move2/
<f+++++++++ Move2/Test 1.txt
22 100% 0.00kB/s 0:00:00 (xfr#1, to-chk=7/9)
<f+++++++++ Move2/Test02.txt
29 100% 28.32kB/s 0:00:00 (xfr#2, to-chk=6/9)
cd+++++++++ Move2/Directory 1/
<f+++++++++ Move2/Directory 1/Testd1 1.txt
71 100% 69.34kB/s 0:00:00 (xfr#3, to-chk=3/9)
<f+++++++++ Move2/Directory 1/Testd1-2.txt
55 100% 53.71kB/s 0:00:00 (xfr#4, to-chk=2/9)
cd+++++++++ Move2/Directory02/
<f+++++++++ Move2/Directory02/Testd2 1.txt
84 100% 82.03kB/s 0:00:00 (xfr#5, to-chk=1/9)
<f+++++++++ Move2/Directory02/Testd2-2.txt
27 100% 26.37kB/s 0:00:00 (xfr#6, to-chk=0/9)
default_perms_for_dir: sys_acl_get_file(Move2/Directory 1, ACL_TYPE_DEFAULT): Permission denied, falling back on umask
rsync: mkstemp "/Move2/Directory 1/.Testd1 1.txt.ZEeQVa" (in archive) failed: Permission denied (13)
rsync: mkstemp "/Move2/Directory 1/.Testd1-2.txt.hL6fWG" (in archive) failed: Permission denied (13)
default_perms_for_dir: sys_acl_get_file(Move2/Directory02, ACL_TYPE_DEFAULT): Permission denied, falling back on umask
rsync: mkstemp "/Move2/Directory02/.Testd2 1.txt.KiAwKl" (in archive) failed: Permission denied (13)
rsync: mkstemp "/Move2/Directory02/.Testd2-2.txt.0EKh6j" (in archive) failed: Permission denied (13)
total: matches=0 hash_hits=0 false_alarms=0 data=288
sent 792 bytes received 827 bytes 1,079.33 bytes/sec
total size is 288 speedup is 0.18
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.0]
total 82 drwxrwx--- 3 Bob bobgroup 3 Jul 14 22:33 ./ drwxr-xr-x 6 root wheel 6 Jul 13 21:56 ../ d--------- 4 Bob bobgroup 6 Jul 14 22:06 Move2/
total 115 drwxrwx--- 4 Bob bobgroup 6 Jul 14 22:06 ./ drwxr-xr-x 6 root wheel 6 Jul 13 21:56 ../ d--------- 2 Bob bobgroup 4 Jul 14 22:08 Directory 1/ d--------- 2 Bob bobgroup 4 Jul 14 22:09 Directory02/ ---------- 1 Bob bobgroup 22 Jul 14 22:06 Test 1.txt ---------- 1 Bob bobgroup 29 Jul 14 22:07 Test02.txt
