problems replacing drive
Bhoot
Hello all. So I just started replacing the second HDD on my freeNAS box. The first one was resilvered without much (or any issues) but this time the story is quite different. I followed the manual "Offline"d the faulty disk>Pulled it out>Put the new disk in and clicked "replace". Now as I remember the last time I did these steps I reached a pop up with a drop down menu with the replaced hard disk showing. This time its blank. :(. The steps are exactly what I followed before just a different result. Please find the pic attached and also the zpool status. Appreciate any help. thanks
[root@freenas] ~# zpool status -v
  pool: bhoot
state: DEGRADED
status: One or more devices has been taken offline by the administrator.
        Sufficient replicas exist for the pool to continue functioning in a
        degraded state.
action: Online the device using 'zpool online' or replace the device with
        'zpool replace'.
  scan: scrub repaired 768K in 73h30m with 0 errors on Mon Jan 18 04:30:12 2016
        bhoot                                           DEGRADED     0     0     0
          raidz2-0                                      DEGRADED     0     0     0
            15718430655639808529                        OFFLINE      0     0     0  was /dev/gptid/cce1f2ca-e4d8-11e4-b39d-f07959376c84
            gptid/cd427285-e4d8-11e4-b39d-f07959376c84  ONLINE       0     0     0
            gptid/cda4f9a1-e4d8-11e4-b39d-f07959376c84  ONLINE       0     0     0
            gptid/ce06b19f-e4d8-11e4-b39d-f07959376c84  ONLINE       0     0     0
            gptid/ce69a75d-e4d8-11e4-b39d-f07959376c84  ONLINE       0     0     0
            gptid/4cfc6072-b5e0-11e5-8742-f07959376c84  ONLINE       0     0     0
            gptid/cf2dd08e-e4d8-11e4-b39d-f07959376c84  ONLINE       0     0     0
            gptid/cf91d6e8-e4d8-11e4-b39d-f07959376c84  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: none requested
        freenas-boot  ONLINE       0     0     0
          da0p2     ONLINE       0     0     0
Bhoot
Hmm not sure what happened exactly but I tried the only thing I did last time. A SHUTDOWN. I shutdown the system removed the wires reinserted them and rebooted. Went to the said menu and this time the dropdown actually had a disk. Not sure what happened exactly but I am happy. The resilvering has started.
  pool: bhoot
state: ONLINE
status: One or more devices is currently being resilvered.  The pool will
        continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
  scan: resilver in progress since Mon Jan 18 17:54:08 2016
        5.04G scanned out of 18.9T at 26.6M/s, 207h15m to go
        608M resilvered, 0.03% done
        NAME                                            STATE     READ WRITE CKS        UM
        bhoot                                           ONLINE       0     0        0
          raidz2-0                                      ONLINE       0     0        0
            gptid/5663b940-bdde-11e5-9e00-f07959376c84  ONLINE       0     0        0  (resilvering)
  pool: freenas-boot
state: ONLINE
          da0p2     ONLINE       0     0     0
m0nkey_
Sounds like your system doesn't support hot swap. Hot swap is for suckers anyway. It's always best to shut down a system to replace a drive.
