Problems replacing Disk
JGDSI
Hi, Pretty new at this :(
I tried to replace a disk as it showed as "FAULTED". As the system is hot swapped, I marked the disk OFFLINE and replaced it with a new one. Then a marked it as "REPLACE". This is what it shows now - I dont have a clue what happened - see attached image.
My zpool status returns this:
[root@freenas2 ~]# zpool status
pool: MAIN
state: DEGRADED
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
scan: scrub repaired 0 in 0 days 16:31:12 with 0 errors on Mon Jun 24 04:27:39 2019
NAME STATE READ WRITE CKSUM
MAIN DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/89256d6c-c476-11e5-bff4-0cc47aa934d4 ONLINE 0 0 0
gptid/8a09bd76-c476-11e5-bff4-0cc47aa934d4 ONLINE 0 0 0
replacing-2 OFFLINE 0 0 0
3398185278903498716 OFFLINE 0 0 0 was /dev/gptid/8af810be-c476-11e5-bff4-0cc47aa93
4d4
792542554290005901 OFFLINE 0 0 0 was /dev/gptid/79c194e5-955a-11e9-9b2f-0cc47aa93
4d4
16678496412740905184 OFFLINE 6 1.21K 0 was /dev/gptid/7b9ffcd9-95e8-11e9-8d9a-0cc47aa93
4d4
gptid/8be2492f-c476-11e5-bff4-0cc47aa934d4 ONLINE 0 0 0
gptid/8cc042fa-c476-11e5-bff4-0cc47aa934d4 ONLINE 0 0 0
gptid/8da416f6-c476-11e5-bff4-0cc47aa934d4 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:06:52 with 0 errors on Thu Jun 20 03:51:52 2019
freenas-boot ONLINE 0 0 0
gptid/28e3a49d-c46f-11e5-a2ac-0cc47aa934d4 ONLINE 0 0 0
PLEASE, help!!!!
EDIT to include Freenas Version 11.2-U4.1
D
dlavigne
Guest
Did the resilver complete? If not, what is the current output of zpool status (within code tags please).
JGDSI
Thanks for responding.
There is no resilvering happening. Not sure it actually did tbh. As I said, very new at this, sorry.
root@freenas2:~ # zpool status
  pool: MAIN
 state: DEGRADED
  scan: resilvered 58.3G in 0 days 00:39:55 with 0 errors on Wed Jun 26 14:42:39                                               2019
        NAME                                              STATE     READ WRITE C                                              KSUM
        MAIN                                              DEGRADED     0     0                                                   0
            replacing-2                                   UNAVAIL      0 6.48K                                                  59
              gptid/8af810be-c476-11e5-bff4-0cc47aa934d4  FAULTED      6 7.05K                                                   0  too many errors
              792542554290005901                          OFFLINE      0     0                                                   0  was /dev/gptid/79c194e5-955a-11e9-9b2f-0cc47aa934d4
              16678496412740905184                        OFFLINE      0     0                                                   0  was /dev/gptid/7b9ffcd9-95e8-11e9-8d9a-0cc47aa934d4
  pool: freenas-boot
 state: ONLINE
root@freenas2:~ #
JGDSI
nope. not at all :(
do you need more info to be able to help me?
thanks!
D
dlavigne
Guest
It's probably worth reporting at bugs.ixsystems.com. If you do, post the issue number here.
