Hello! ,
I am the newest to the forum, just registered and just installed FreeNAS.
I've been testing this OS for a week for my own NAs in production. Several formats later and various readings on FreeNAS networks and others.
Finally, once everything is clarified, I am in the final phase of installation and commissioning.
Calmly and step by step. All right..
As I was not going to follow the process today, I decided to shut down the server with Option 11 of the console. The shutdown of everything begins and there comes a time when the shutdown hangs right on the line that I cannot see everything but says:
DB: enter: executed AML Breackpoint opcode
thread pid 1 tid 100002]
topped at kdb_enter + 0x3b: movq $ 0, kdb_why
b: 0: kbd.enter.default> write cn_mute 1
n_mute 0 = 0x1
b: 0: kbd.enter .default> textdump dup
And he stands still ...
If I turn it off from the web interface it only does a restart it does not turn off ....
I read something to load in bios the default configuration I did and that's why I see the monitor interface cut .. But it still doesn't turn off
The equipment configuration is as follows:
HP ProLiant MicroServer Gen10 AMD Opteron X3216 1.6 GHz 8GB RAM DDR4 Server
Processor / Chipset
AMD Opteron X3216 / 1.6 GHz CPU
Max turbo speed 3 GHz
Number of Dual-Core cores
CPU # 1
Maximum number of CPU 1
Update level of
Upgradable CPU
Cache
Installed size 1 MB
Cache per processor 1 MB
RAM
Installed size 8GB / 32GB (max.)
DDR4 SDRAM technology - ECC
Memory speed
effective 2400 MHz
Memory speed
nominal 2400 MHz
288-pin DIMM form factor
Features No buffer memory
HDD
4x 2TB Seagate ironwolf 5900rpm
1x250gb WD green SSD
Storage controller
SATA type
Controller type SATA 6Gb / s interface
Storage Controller Name Marvell 88SE9230
RAID level RAID 0, RAID 1, RAID 10
Monitor
Samsung led.
Graphics Controller
VGA video interfaces
Network connection
2 x Gigabit Ethernet ports
Broadcom BCM5720 Ethernet Controller
Interconnection protocol
Ethernet data, Fast Ethernet, Gigabit Ethernet
Features Wake on LAN (WoL), PXE compatible
Expansion / Connectivity
Bays 1 (total) / 1 (free) x external 5.25 "
4 (total) / 4 (free) x internal 3.5 "LFF
Grooves
1 (total) / 1 (free) x PCIe 3.0 x8 - low profile
2 288-pin DIMMs
1 (total) / 0 (free) x CPU
1 (total) / 1 (free) x PCIe 3.0 x4 - low profile (x1 mode)
Interfaces
1 x VGA
3 x USB 2.0 (2 rear, 1 internal)
2 x LAN (Gigabit Ethernet)
4 x USB 3.0 (2 front, 2 rear)
Diverse
Compliance with ICES-003, EN55024, EMC, FCC CFR47 Part 15, ACPI 5.0, GB 9254, CNS
13438, EN61000-3-2, EN61000-3-3, K24, CISPR 32, EN 55032
Feeding
Device type Power supply
Nominal AC voltage 120/230 V (50/60 Hz)
Power supplied 200 watts
Operating systems / Software
FreeNAS
Certified OS Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016
Manufacturer's guarantee
Service and maintenance Limited warranty - parts and labor - 1 year - on-site
Dimensions and weight
Width 23 cm
Depth 25.4 cm
Height 23.5 cm
Weight 6.5 kg
Environment parameters
Minimum temperature of
10 ° C operation
Maximum temperature of
35 ° C operation
Humidity range of
10 to 90% operation (non-condensing)
Any recommendation solution? Thanks in advance.
n_mute 0 = 0x1
Processor / Chipset
CPU # 1
Update level of
Upgradable CPU
Cache
Installed size 1 MB
RAM
Memory speed
effective 2400 MHz
Memory speed
nominal 2400 MHz
HDD
Storage controller
SATA type
Monitor
Samsung led.
Graphics Controller
Network connection
Grooves
2 288-pin DIMMs
Interfaces
1 x VGA
Diverse
Feeding
FreeNAS
Width 23 cm
Depth 25.4 cm
Height 23.5 cm
Weight 6.5 kg
10 ° C operation
35 ° C operation
Humidity range of
