Kakistocrtor
- Oct 16, 2016
I'm currently migrating to new hardware and ran into some irritating problems when trying to import my jails on the new server. Some things didn't work as expected.
Here's what I did, on a nearly untouched FreeNAS installation (created a few users, samba shares, and installed the emby plugin):
I exported a jail on my old server using
The new jail was displayed with the name OFF by
The jail wasn't displayed at all using the
It was displayed in the FreeNAS GUI using the original hostname "murmur", not "OFF".
Trying to interact with the jail in the GUI resulted in an error discussed on these forums before, caused by multiple jails having the same ID - the imported jail was assigned ID 1, which, of course, was already in use. Setting a new unique ID in .OFF.meta/id manually solved that problem, but I don't think thats how this is supposed to work - where did I go wrong there?
Trying to start the jail from the GUI displayed
Jail successfully started.
but didn't have any other results. In particular the jail wasn't started.
I tried setting a static IP for the jail in the GUI. That failed without displaying any error. Setting one manually in .OFF.meta/ipv4 worked - I still couldn't start the jail using the gui, but it started without error using
I still wasn't able to interact with it in any interesting way from the gui, in particular I couldn't mount any storage. The gui just kept loading when I tried to choose the mount destination in the jail.
My questions are:
Is what I experienced expected behaviour? How does it differ from expected behaviour?
How are the names of the jails displayed by
What should I do to import jails with the correct name and a unique id? What should I do to be able to interact with these jails from the gui (especially to add storage) and to have them use DHCP instead of static IPs (while retaining the ability to start them...)?
I looked for information on this in the FreeNAS and Warden documentation but wasn't able to find anything that helped me. When creating new jails with the warden it seems to be possible to configure them to use DHCP, but not when importing...
I hope I have explained my problem properly and didn't miss any important information. If you want me to clarify something or provide additional info, please ask.
warden export and copied it to the new server. I used warden import to import it, which executed without displaying any kind of error.The new jail was displayed with the name OFF by
warden list, and this is also the name used for the jail and meta folder in my jail root directory. I expected it to use the original name ("murmur") from the old system.The jail wasn't displayed at all using the
jls command. It was displayed in the FreeNAS GUI using the original hostname "murmur", not "OFF".
warden start murmur didn't work because ERROR: No such jail! warden start OFF looked better, but failed because the jail was configured to use DHCP:Code:
Mounting user-supplied file-systems ifconfig: DHCP/: bad value (width invalid) jail -c path=/mnt/main/jails/OFF ip4.addr=DHCP/ host.hostname=murmur allow.raw_sockets=true persist jail: ip4.addr: not an IPv4 address: DHCP ERROR: Failed starting jail with above command... Unmounting /mnt/main/jails/OFF/proc
warden start. It was still displayed as turned off in the gui, but it ran perfectly fine (logged in via SSH and played around a bit). Also, it was now displayed by jls:Code:
JID IP Address Hostname Path 5 - emby_1 /mnt/main/jails/emby_1 6 192.168.199.240 murmur /mnt/main/jails/OFF
My questions are:
warden list, the gui and jls connected? How are they connected to the names used for the directories in the jails root directory?What should I do to import jails with the correct name and a unique id? What should I do to be able to interact with these jails from the gui (especially to add storage) and to have them use DHCP instead of static IPs (while retaining the ability to start them...)?
