eborduas
- Nov 2, 2020
I have 2 TrueNAS installation, freenas and truenas-rep which are connect as shown in the below network diagram.
I am able to create an SSH Connection from freenas to truenas-rep over both the 192.168.1.1/24 and 192.168.1.3/24 networks. But cannot create an SSH Connection from truenas-rep to freenas over either networks.
I can ping truenas-rep from freenas over both netwroks and the reverse as well.
When I attempt to create an SSH Connection from truenas-rep to freenas over either networks I get the following error:
The password is correct since I can use it, the password, to log into the web UI. I've tried with a different username/password and the same error is generated.
My goal is to establish pull replication from truenas-rep but the above error is preventing that and for now I need to settle for push replication from freenas.
Any suggestions?
freenas% ping 192.168.3.2 PING 192.168.3.2 (192.168.3.2): 56 data bytes 64 bytes from 192.168.3.2: icmp_seq=0 ttl=64 time=1.500 ms freenas% ping 192.168.1.250 PING 192.168.1.250 (192.168.1.250): 56 data bytes 64 bytes from 192.168.1.250: icmp_seq=0 ttl=64 time=0.215 ms truenas-rep% ping 192.168.3.1 PING 192.168.3.1 (192.168.3.1): 56 data bytes 64 bytes from 192.168.3.1: icmp_seq=0 ttl=64 time=1.587 ms truenas-rep% ping 192.168.1.253 PING 192.168.1.253 (192.168.1.253): 56 data bytes 64 bytes from 192.168.1.253: icmp_seq=0 ttl=64 time=0.217 ms
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 139, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1247, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1152, in run_in_executor
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 985, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/keychain.py", line 584, in remote_ssh_semiautomatic_setup
raise CallError(f"Semi-automatic SSH connection setup failed: {e!r}")
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/keychain.py", line 573, in remote_ssh_semiautomatic_setup
raise CallError("Invalid password")
middlewared.service_exception.CallError: [EFAULT] Invalid password
Any suggestions?
