I'm using SMB for network file access but do have massive problems with copying data from FreeNAS over SMB from my Linux Mint.
My system setup:
When trying to copy files from a FreeNAS share to a FreeNAS share or to my Mint PC the copy task stops sometimes nearly immediately. The copy window shows e.g. "copying 1 of 20 files" but nothing happens, sometimes one or more files are copied, mostly it stops after first file. Nothing happens after that. I need to stop nemo process on my Mint to exit this copy job.
When it stops on a specific amount of data it stops always I try it, so it is reproducible. When copy job ends up successful I can also reproduce this successful copy job again.
I do not have those problems on a Windows Machine!
Could there be a problem with my fstab entry? I have no idea where to search for the problem :( and appreciate any help.
My system setup:
- FreeNAS Storage encrypted
- no special SMB Service settings (SMB v1 not active)
- Client PC is a Linux Mint
- fstab entry: //fserver_name/share_name /.../share_name cifs credentials=/.../.cred,uid=1026,gid=1000,vers=3.0 0 0
