I am recreating my pool in order to align them in 4k, but every time I try to create it using the wizard, the ashift value shows 9 instead of 12. Manually creating the partition on disk and zpool is able to produce ashift 12, but I am unable to import the volume in FreeNAS GUI.
My spec is:
X10SRL-F
E5-1650V3
64GB DDR4 ECC
12x Toshiba 5TB MD04ACA500
Intel 750 400GB NVMe
SanDisk 64GB USB
My spec is:
X10SRL-F
E5-1650V3
64GB DDR4 ECC
SanDisk 64GB USB
