I've been running 0.7.2 for a while now, and decided to switch to 8.0 today. My hardware is a mini-ITX with D525 Atom, along with 2GBs of RAM and 3 hard drives:
- 1x 16GB SSD for the system
- 2x 2TB green drives for the storage
The big drives are configured as mirrored raid, and after booting my raid bios will show both drives as active raid configuration.
Now, after installing 8.0 from scratch on the 16GB drive, I can't seem to select my raid drive in the freenas gui. Iirc, I was presented 3 devices under freenas 0.7.2 - that is ad* (twice) which were the two 2TB drives, as well as a ra* device, which was the raid volume.
On 8.0, I can use the import volume function, but I can only select either ada0p1 or ada1p1, both shown as 2TB drives, but I can't seem to find my raid volume. I didnt select anything yet, because I'm afraid I would only write data to one of the drives of the raid. Am I doing something wrong?
Also, I tried to install a package using pkg_add -r, but I got plenty of errors that the var space is full. df actually showed:
How can I fix this problem, so I can install packages? Also, why doesn't freenas use the full space of the 16GB drive? I remember under 0.7 I was prompted how much space for the partitions I want, now it seems I got some default partitions that don't make use of all the space available :(
freenas# df -h Filesystem Size Used Avail Capacity Mounted on /dev/ufs/FreeNASs1a 458M 399M 22M 95% / devfs 1.0K 1.0K 0B 100% /dev /dev/md0 4.4M 2.3M 1.8M 57% /etc /dev/md1 686K 6.0K 626K 1% /mnt /dev/md2 75M 12M 56M 18% /var /dev/ufs/FreeNASs4 20M 341K 18M 2% /data
freenas# pkg_add -r openjdk6 Fetching ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.2-release/Latest/openjdk6.tbz... /var: write failed, filesystem is full openjdk6/jre/lib/rt.jar: Write failed /var: write failed, filesystem is full openjdk6/jre/lib/security/cacerts: Write failed openjdk6/jre/lib/security/java.policy: Seek failed openjdk6/jre/lib/security/java.security: Seek failed openjdk6/jre/lib/security/local_policy.jar: Seek failed openjdk6/jre/lib/sound.properties: Seek failed openjdk6/jre/lib/zi/Africa/Abidjan: Seek failed openjdk6/jre/lib/zi/Africa/Accra: Seek failed openjdk6/jre/lib/zi/Africa/Addis_Ababa: Seek failed openjdk6/jre/lib/zi/Africa/Algiers: Seek failed openjdk6/jre/lib/zi/Africa/Asmara: Seek failed openjdk6/jre/lib/zi/Africa/Bamako: Seek failed openjdk6/jre/lib/zi/Africa/Bangui: Seek failed openjdk6/jre/lib/zi/Africa/Banjul: Seek failed ...... many more errors. aborted it.
