Probleme mit iSCSI
Atomic
Moin,
in den letzten Tagen habe ich ein wenig mit iSCSI bei FreeNAS und Mac OS X rumgespielt, habe es aber leider nicht geschafft das Target am Mac zu mounten.
Ich habe zu Testzwecken zwei LUNs erstellt, Block1 mit Hilfe des Wizards und Block2 manuell. Beide Targets werden von dem Small-Tree iSCSI Manager gesehen und zumindest das Block1 gemountet aber der Mac bemerkt die neue Festplatte nicht.
FreeNAS IP: 192.168.11.23
MacPro IP: 192.168.11.20
Jul 24 20:18:23 freenas epair1a: Ethernet address: 02:a5:26:00:0a:0a
Jul 24 20:18:23 freenas epair1b: Ethernet address: 02:a5:26:00:0b:0b
Jul 24 20:18:23 freenas kernel: epair1a: link state changed to UP
Jul 24 20:18:23 freenas kernel: epair1b: link state changed to UP
Jul 24 20:18:23 freenas kernel: epair1a: promiscuous mode enabled
Jul 24 20:18:23 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair1b
Jul 24 20:28:19 freenas afpd[7882]: Login by nilsstorm (AFP3.4)
Jul 24 20:28:35 freenas afpd[7935]: Login by macpro (AFP3.4)
Jul 24 20:29:25 freenas ctld[1776]: portal-group "pg2" not assigned to any target
Jul 24 20:29:25 freenas ctld[1776]: auth-group "ag4tg_1" not assigned to any target
Jul 24 20:29:41 freenas ctld[1776]: portal-group "pg2" not assigned to any target
Jul 24 20:29:41 freenas ctld[1776]: auth-group "ag4tg_1" not assigned to any target
Jul 24 20:34:12 freenas ctld[1776]: no LUNs defined for target "iqn.2011-03.org.example.istgt:block2target"
Jul 24 20:34:12 freenas ctld[1776]: auth-group "ag4tg_1" not assigned to any target
Jul 24 20:34:12 freenas ctld[1776]: auth-group "ag4tg_2" not assigned to any target
Jul 24 20:37:57 freenas kernel: arp: 192.168.11.23 moved from 02:a5:26:00:0a:0a to 70:54:d2:45:e0:88 on epair1b
Jul 24 20:37:57 freenas kernel: arp: 192.168.11.23 moved from 02:3b:4e:00:09:0a to 70:54:d2:45:e0:88 on epair0b
Jul 24 20:38:25 freenas ctld[1776]: no LUNs defined for target "iqn.2011-03.org.example.istgt:block2target"
Jul 24 20:38:25 freenas ctld[1776]: auth-group "ag4tg_1" not assigned to any target
Jul 24 20:38:25 freenas ctld[1776]: auth-group "ag4tg_2" not assigned to any target
Jul 24 20:38:51 freenas ctld[1776]: no LUNs defined for target "iqn.2011-03.org.example.istgt:block2target"
Jul 24 20:38:51 freenas ctld[1776]: auth-group "ag4tg_1" not assigned to any target
Jul 24 20:38:51 freenas ctld[1776]: auth-group "ag4tg_2" not assigned to any target
Jul 24 20:41:51 freenas ctld[1776]: no LUNs defined for target "iqn.2011-03.org.example.istgt:block2target"
Jul 24 20:41:51 freenas ctld[1776]: auth-group "ag4tg_1" not assigned to any target
Jul 24 20:41:51 freenas ctld[1776]: auth-group "ag4tg_2" not assigned to any target
Jul 24 20:42:20 freenas ctld[1776]: auth-group "ag4tg_1" not assigned to any target
Jul 24 20:42:20 freenas ctld[1776]: auth-group "ag4tg_2" not assigned to any target
Jul 24 20:43:54 freenas ctld[17984]: 192.168.11.20 (iqn.2003-12.com.small-tree:nils-mac-pro.local): requested target "iqn.2011-03.org.example.istgt:block1target" not found
Jul 24 20:43:54 freenas ctld[1776]: child process 17984 terminated with exit status 1
Jul 24 20:46:02 freenas ctld[18093]: 192.168.11.20 (iqn.2003-12.com.small-tree:nils-mac-pro.local): requested target "iqn.2011-03.org.example.istgt:block1target" not found
Jul 24 20:46:02 freenas ctld[1776]: child process 18093 terminated with exit status 1
Was mache ich falsch?
Atomic
Moin,
ja, ich hab Extents definiert.
