Hab ein wenig gegooglet, in älteren Threads wurde empfohlen eine, oder mehrere HDDs raus zu nehmen.
Freenas startet mit der ada0 HDD; bin dann in die Shell gegangen und habe mit "zpool Status" & "zpool Import" folgende Infos.
Last login: Sat Jan 4 23:23:47 on pts/2
FreeBSD 11.2-STABLE (FreeNAS.amd64) #0 r325575+c9231c7d6bd(HEAD): Mon Nov 18 22:46:47 UTC 2019
FreeNAS (c) 2009-2019, The FreeNAS Development Team
All rights reserved.
FreeNAS is released under the modified BSD license.
For more information, documentation, help or support, go here:
TrueNAS is the World's #1 Open Source Storage. Based on OpenZFS, it is trusted by millions and deployed worldwide.
freenas.org
Welcome to FreeNAS
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@cubebot[~]# zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:05 with 0 errors on Thu Jan 2 03:45:05 2020
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
nvd0p2 ONLINE 0 0 0
errors: No known data errors
root@cubebot[~]# zpool import
pool: HDD1
state: DEGRADED
status: One or more devices were being resilvered.
action: The pool can be imported despite missing or damaged devices. The
fault tolerance of the pool may be compromised if imported.
HDD1 DEGRADED
mirror-0 DEGRADED
ada0p2 ONLINE
replacing-1 UNAVAIL insufficient replicas
3211802980765960678 UNAVAIL cannot open
4594119477161220000 UNAVAIL cannot open
root@cubebot[~]#
