PROBLEMAS FreeNAS-9.2.1.8-RELEASE-x64 (e625626)
digiscps
PESSOAL PRECISO DE AJUDA URGENTE, DEPOIS CREIO EU QUE ATUALIZEI O FREENAS NA OPÇÃO AUTOMÁTICA, O MESMO NÃO SOBE MAIS, FICA COM A MENSAGEM ABAIXO;
NÃO CONSIGO ACESSAR O MESMO NEM POR VIA DE SSH, ALGUÉM PODERIA NOS AJUDAR ?
OLHEM O POST DE ERRO: TEMOS 5XHB 3TB SATA3 = 15GB
Request Method: GET
Request URL: http://192.168.1.168/
Software Version: FreeNAS-9.2.1.8-RELEASE-x64 (e625626)
Exception Type: OperationalError
Exception Value:
no such table: system_advanced
Exception Location: /usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py in execute, line 451
Server time: Wed, 31 May 2017 12:49:35 +0000
Traceback
Request information
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
No cookie data
META
Variable Value
wsgi.multiprocess False
REDIRECT_STATUS '200'
SERVER_SOFTWARE 'nginx/1.4.4'
SCRIPT_NAME u''
REQUEST_METHOD 'GET'
PATH_INFO u'/'
SERVER_PROTOCOL 'HTTP/1.1'
QUERY_STRING ''
CONTENT_LENGTH ''
HTTP_USER_AGENT 'Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/58.0.3029.110 Safari/537.36'
HTTP_CONNECTION 'keep-alive'
SERVER_NAME 'localhost'
REMOTE_PORT '62906'
wsgi.url_scheme 'http'
SERVER_PORT '80'
SERVER_ADDR '192.168.1.168'
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
DOCUMENT_URI '/'
wsgi.input <flup.server.fcgi_base.InputStream object at 0x80f63c190>
HTTP_HOST '192.168.1.168'
wsgi.multithread True
HTTP_UPGRADE_INSECURE_REQUESTS '1'
REQUEST_URI '/'
HTTP_ACCEPT 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8'
wsgi.version (1, 0)
GATEWAY_INTERFACE 'CGI/1.1'
wsgi.run_once False
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x80f63c410>
REMOTE_ADDR '192.168.1.252'
HTTP_ACCEPT_LANGUAGE 'pt-BR,pt;q=0.8,en-US;q=0.6,en;q=0.4'
CONTENT_TYPE ''
HTTP_ACCEPT_ENCODING 'gzip, deflate, sdch'
melloa
Não faço a mínima idéia, portanto vou deixar os gurus fazerem o troubleshoot, mas por que não tentar dar o boot usando o environment anterior? Bote um monitor e teclado no servidor, boot, selecione a opção de Boot Enviroment Menu -> selecione o boot anterior e <ENTER>
digiscps
COLEGA NÃO ENTENDI, MEU BOOT ESTA AUTOMÁTICO E NÃO CHEGA NESTA TELA ??? COMPLICADO ?
melloa
ESTAS DIZENDO QUE QUANDO VOCE LIGA SEU SERVIDOR VOCE NAO VE NADA NA TELA, INCLUINDO AS TELAS ACIMA? Ops ... o caps lock tava ligado ...
digiscps
SEGUE AS TELAS DE INICIALIZAÇÃO DO MEU FREENAS
Isso é o bootloader antigo, até à versão 9.2.1.9.
Que tentativa de update foi essa? Melhor dito, para que versão?
O que eu recomendo é guardar um backup da configuração, fazer uma instalação limpa de uma versão 9.3, depois fazer o update para a mais recente, 9.10.2-U4.
melloa
Como? O servidor trava no meio do boot. Perguntei a ele se podia usar a opcao de entrar no shell (opcao 3) para isso e ele disse que nao funcionava.
Em tempo: Gostaria de saber para aprender, nao estou criticando.
Vai-se buscar directamente ao disco. Como é UFS, abre-se facilmente em quase qualquer Unix. Para além disso, no outro thread com excesso de maiúsculas pareceu-me ter lido acerca de um backup existente.
melloa
ah! Foi o que sugerí também. Montar num sistema unix-like, copiar o config, reinstalar num boot novo, importar volume, config, etc.
Será que 9.3 seria compatível ou melhor a versão antiga dele?
A longo prazo convém fazer o update, portanto eu despacharia o assunto agora já que é preciso estar a alterar coisas.
Se a versão original for 9.2.1.6 ou mais recente, não deve haver grandes problemas. É só passar pela 9.3 primeiro, porque a 9.10.2 só consegue migrar da 9.3 para a frente.
melloa
Entendido. Creio que o usuário tem todas as informações que precisa, agora é mão na massa.
digiscps
bom dia galera, problemas resolvido, feito no pen drive conforme foi passado acima, agora apenas criar os acessos...Obrigado a todos.
