Приветствую!
Установил Jail Virtualbox, но не могу зацепить хранилище... Вот что выдает:
Request Method: POST
Request URL: http://XXXXXXXX/admin/jails/nullmountpoint/edit/2/
Software Version: FreeNAS-9.2.1.8-RELEASE-x64 (e625626)
Exception Type: UnicodeDecodeError
Exception Value:
'ascii' codec can't decode byte 0xd0 in position 18: ordinal not in range(128)
Exception Location: /usr/local/www/freenasUI/../freenasUI/freeadmin/options.py in edit, line 561
Server time: Вск, 7 Дек 2014 17:11:33 +0700
Unicode error hint
The string that could not be encoded/decoded was: ror: ������
Environment:
Request URL: http://XXXXXX/admin/jails/nullmountpoint/edit/2/
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
107. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view
158. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
22. return view_func(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/options.py" in wrapper
209. return self._admin.admin_view(view)(*args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/utils/decorators.py" in _wrapped_view
99. response = view_func(request, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/views/decorators/cache.py" in _wrapped_view_func
52. response = view_func(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/site.py" in inner
144. return view(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/options.py" in edit
561. message=_(u"Error: %s") % unicode(e))
Exception Type: UnicodeDecodeError at /admin/jails/nullmountpoint/edit/2/
Exception Value: 'ascii' codec can't decode byte 0xd0 in position 18: ordinal not in range(128)
Request information
GET
No GET data
POST
Variable Value
__form_id u'dialogForm_\u0425\u0440\u0430\u043d\u0438\u043b\u0438\u0449\u0435'
__all__ u''
mpjc_path u'/mnt/raid1/jails'
create u'on'
destination u'/mnt'
source u'/mnt/raid1'
jail u'VBox1'
mounted u'on'
FILES
No FILES data
COOKIES
Variable Value
csrftoken XXXXXXXXXXX
sessionid 'XXXXXXXXXXX'
fntreeSaveStateCookie ZXXXXXXXXXXXXXXX
META
Variable Value
wsgi.multiprocess False
HTTP_REFERER 'http://XXXXXXXX/'
REDIRECT_STATUS '200'
SERVER_SOFTWARE 'nginx/1.4.4'
SCRIPT_NAME u''
HTTP_X_CSRFTOKEN
REQUEST_METHOD 'POST'
PATH_INFO u'/admin/jails/nullmountpoint/edit/2/'
SERVER_PROTOCOL 'HTTP/1.1'
QUERY_STRING ''
CONTENT_LENGTH '190'
HTTP_USER_AGENT 'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:33.0) Gecko/20100101 Firefox/33.0'
HTTP_CONNECTION 'keep-alive'
HTTP_COOKIE '
SERVER_NAME 'localhost'
REMOTE_PORT '40738'
wsgi.url_scheme 'http'
SERVER_PORT '80'
SERVER_ADDR '192.168.1.250'
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
HTTP_PRAGMA 'no-cache'
HTTP_CONTENT_LENGTH '190'
HTTP_X_REQUESTED_WITH 'XMLHttpRequest'
DOCUMENT_URI '/admin/jails/nullmountpoint/edit/2/'
wsgi.input <flup.server.fcgi_base.InputStream object at 0x810042210>
HTTP_DNT '1'
HTTP_HOST '94.251.9.94:8080'
wsgi.multithread True
HTTP_CACHE_CONTROL 'no-cache'
HTTP_CONTENT_TYPE 'application/x-www-form-urlencoded; charset=UTF-8'
REQUEST_URI '/admin/jails/nullmountpoint/edit/2/'
HTTP_ACCEPT 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8'
wsgi.version (1, 0)
GATEWAY_INTERFACE 'CGI/1.1'
wsgi.run_once False
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x810042d50>
REMOTE_ADDR '192.168.1.1'
HTTP_ACCEPT_LANGUAGE 'ru-RU,ru;q=0.8,en-US;q=0.5,en;q=0.3'
CSRF_COOKIE u'LjzdSBVmVtvLa6a1tyI0QfnbLwsTanew'
HTTP_ACCEPT_ENCODING 'gzip, deflate'
Погуглил... нашлось только то, что кодировка не совпадает. Как поправить или я в принципе что-то не так делаю? Строго не судите, я только начал щупать freenas...
Exception Value:
Unicode error hint
Environment:
Traceback:
Request information
GET
No GET data
POST
Variable Value
__all__ u''
create u'on'
destination u'/mnt'
jail u'VBox1'
mounted u'on'
FILES
No FILES data
COOKIES
Variable Value
META
Variable Value
SCRIPT_NAME u''
HTTP_X_CSRFTOKEN
QUERY_STRING ''
HTTP_COOKIE '
REMOTE_PORT '40738'
SERVER_PORT '80'
HTTP_DNT '1'
wsgi.version (1, 0)
wsgi.run_once False
