Доброго времени суток, коллеги
Никак не могу понять чего хочет от меня FreeNAS...
При обновлении выдает ошибку:
Firmware Update:
Environment: Software Version: FreeNAS-9.1.0-RC2-x64 (5f710b2) Request Method: POST Request URL: https://192.168.0.170/system/firmwizard/?X-Progress-ID=ad498d4e-ae49-4940-86c6-2b91929f0fd4 Traceback: File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 109. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view 165. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 25. return view_func(request, *args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/views/generic/base.py" in view 68. return self.dispatch(request, *args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in dispatch 227. response = super(WizardView, self).dispatch(request, *args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/views/generic/base.py" in dispatch 86. return handler(request, *args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in post 290. return self.render_done(form, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in render_done 332. done_response = self.done(final_form_list, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/system/forms.py" in done 157. retval = notifier().validate_update(path) File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in validate_update 2335. stderr=subprocess.STDOUT, File "/usr/local/lib/python2.7/subprocess.py" in check_output 568. process = Popen(stdout=PIPE, *popenargs, **kwargs) File "/usr/local/lib/python2.7/subprocess.py" in __init__ 711. errread, errwrite) File "/usr/local/lib/python2.7/subprocess.py" in _execute_child 1308. raise child_exception Exception Type: OSError at /system/firmwizard/ Exception Value: [Errno 2] No such file or directory
С уважением.
Firmware Update:
С уважением.
