beralt
- Jan 8, 2019
Hello everyone,
since an update from FreeNAS 11.3.U2 (via 11.3.U5) to TrueNAS 12.0 I have problems with my LSI HBA.
Error messages are as follows.
My adapter is the following:
I initially reported the failures in this thread, but at that time, I was not sure yet what exactly caused my problems.
After shutting down all VMs and unmounting all the NFS shares from other machines, the system ran stable without errors, so I marked the old thread with solved.
Since then, I have further managed (after lots of trouble due to the supermicro firmware) to finally upgrade the firmware to the current version (20.00.07).
However, after restarting VMs and/or mounting network drives again, the errors came back.
I also found this thread reporting similar errors on another (equivalent?) LSI HBA, which seems to be the same as mine.
In any case, the current situation leaves my pool constantly degraded, with the only solution to fix it being disconnecting everything and scrubbing/resilvering.
I have not upgraded my pool to the new zfs version, since I am afraid that then there is no possibility of going back. Unfortunately, downgrading easily from TrueNAS 12.0 back to FreeNAS 11.2 seems not to be easily possible.
Does anyone else have these problems and/or a solution? Is there a place (upstream?) to report this bug? Any ideas?
(Edit info: (the original version of the thread stated that I can from FreeNAS 11.2. I just realized that this was not true. I did the upgrade from 11.3.U2 (via 11.3.U5) to TrueNAS - sorry for my confusion)
For completeness, my system specs:
mps0: Unfreezing devq for target ID 11 mps0: Unfreezing devq for target ID 9 mps0: Unfreezing devq for target ID 8 mps0: Unfreezing devq for target ID 10 mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> (da1:mps0:0:9:0): READ(16). CDB: 88 00 00 00 00 01 0f a6 ed 40 00 00 00 58 00 00 length 45056 SMID 1032 Command timeout on target 9(0x0012) 60000 set, 60.78298837 elapsed mps0: Sending abort to target 9 for SMID 1032 (da1:mps0:0:9:0): READ(16). CDB: 88 00 00 00 00 01 0f a6 ed 40 00 00 00 58 00 00 length 45056 SMID 1032 Aborting command 0xfffffe00f94c1ac0 (da0:mps0:0:8:0): READ(16). CDB: 88 00 00 00 00 01 0c ca 3e f8 00 00 00 a0 00 00 length 81920 SMID 23 Command timeout on target 8(0x0011) 60000 set, 60.212799327 elapsed mps0: Sending abort to target 8 for SMID 23 (da0:mps0:0:8:0): READ(16). CDB: 88 00 00 00 00 01 0c ca 3e f8 00 00 00 a0 00 00 length 81920 SMID 23 Aborting command 0xfffffe00f946cee8 (da1:mps0:0:9:0): READ(16). CDB: 88 00 00 00 00 01 0e 8f dc 58 00 00 00 b0 00 00 length 90112 SMID 938 Command timeout on target 9(0x0012) 60000 set, 60.179161024 elapsed (da0:mps0:0:8:0): READ(16). CDB: 88 00 00 00 00 01 0e 98 68 88 00 00 00 b0 00 00 length 90112 SMID 856 Command timeout on target 8(0x0011) 60000 set, 60.170157947 elapsed (da1:mps0:0:9:0): READ(16). CDB: 88 00 00 00 00 01 0f a7 ff 00 00 00 00 60 00 00 length 49152 SMID 1451 Command timeout on target 9(0x0012) 60000 set, 60.235819399 elapsed (da1:mps0:0:9:0): READ(16). CDB: 88 00 00 00 00 01 0f a7 fe 00 00 00 01 00 00 00 length 131072 SMID 1330 Command timeout on target 9(0x0012) 60000 set, 60.300601997 elapsed (da0:mps0:0:8:0): READ(10). CDB: 28 00 6a 58 97 50 00 01 00 00 length 131072 SMID 653 Command timeout on target 8(0x0011) 60000 set, 60.366707821 elapsed (da0:mps0:0:8:0): READ(10). CDB: 28 00 6a 58 96 50 00 01 00 00 length 131072 SMID 1097 Command timeout on target 8(0x0011) 60000 set, 60.424795289 elapsed (da0:mps0:0:8:0): READ(10). CDB: 28 00 6a 58 95 50 00 01 00 00 length 131072 SMID 989 Command timeout on target 8(0x0011) 60000 set, 60.483236665 elapsed (da0:mps0:0:8:0): READ(10). CDB: 28 00 6a 58 94 50 00 01 00 00 length 131072 SMID 354 Command timeout on target 8(0x0011) 60000 set, 60.541325694 elapsed (da3:mps0:0:11:0): WRITE(16). CDB: 8a 00 00 00 00 01 94 5a 70 08 00 00 01 00 00 00 length 131072 SMID 519 Command timeout on target 11(0x0013) 60000 set, 60.401041195 elapsed mps0: Sending abort to target 11 for SMID 519 (da3:mps0:0:11:0): WRITE(16). CDB: 8a 00 00 00 00 01 94 5a 70 08 00 00 01 00 00 00 length 131072 SMID 519 Aborting command 0xfffffe00f9496968 (da2:mps0:0:10:0): WRITE(16). CDB: 8a 00 00 00 00 01 94 5a 70 08 00 00 01 00 00 00 length 131072 SMID 67 Command timeout on target 10(0x0015) 60000 set, 60.538075190 elapsed mps0: Sending abort to target 10 for SMID 67 (da2:mps0:0:10:0): WRITE(16). CDB: 8a 00 00 00 00 01 94 5a 70 08 00 00 01 00 00 00 length 131072 SMID 67 Aborting command 0xfffffe00f9470a08 (da1:mps0:0:9:0): WRITE(16). CDB: 8a 00 00 00 00 01 8c 42 01 78 00 00 00 08 00 00 length 4096 SMID 399 Command timeout on target 9(0x0012) 60000 set, 60.676508524 elapsed (da0:mps0:0:8:0): WRITE(16). CDB: 8a 00 00 00 00 01 8c 42 01 78 00 00 00 08 00 00 length 4096 SMID 1316 Command timeout on target 8(0x0011) 60000 set, 60.740991674 elapsed (xpt0:mps0:0:9:0): SMID 4 task mgmt 0xfffffe00f946b560 timed out mps0: Reinitializing controller mps0: Unfreezing devq for target ID 10 mps0: Unfreezing devq for target ID 9 mps0: Unfreezing devq for target ID 8 mps0: Unfreezing devq for target ID 11 mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
mps0 Adapter: Board Name: LSI2116-IT Board Assembly: Chip Name: LSISAS2116 Chip Revision: ALL BIOS Revision: 7.37.01.00 Firmware Revision: 20.00.07.00
- Supermicro X10SDV-4C-7TP4F
- Intel® Xeon® processor D-1518, Single socket FCBGA 1667; 4-Core, 8 Threads, 35W
- 48 GB RAM
- 4xWD Red 2TB for storage, 2x32GB SanDisk USB SSD drives for system
