Problem with freenas jail nextcloud plugin configuring SSL
Stampey74
hi I installed freenas 12.2_u5 with jail and the nextcloud plugin, now I'm trying to configure the SSL connection but I can't find the configuration files and I don't know if by chance I'm in nginx, you can help me kindly. Thank you
If you want SSL for Nextcloud, just use my script to install it--it handles the cert and all the relevant configuration for you automatically. If you mess with the configuration inside the plugin, you risk it breaking with future updates to the plugin. But yes, the plugin uses nginx.
