Hello.
I try latest FreeNas on asus p5wdg2-ws rev. 1.02g motherboard.
With intel sata controller no problem but with Marvell 6141 sata controller after create raid volume and write some data for test, at console I get some errors about disk delay and disconnect.
After reboot the system cannot start either because can't recognize the raid volume.
If I create raid volume only on intel controller no problem, if create on Marvell controller only or together with intel controller, I get the above errors.
The disks itself are ok, tested several times.
Also at windows, Marvell works fine with it driver.
Maybe there is any new driver for FreeBSD or any solution to my problem?
Thanks at advance.
Sent from iDima using My Mind.
Thanks at advance.
