problem in the disk
B
Barak Michaeli
Guest
hi im new in freenas 8,
i have 2X1T
but when i tried to make a jabod it dosent work.
on the screen its says:
i tried it on freenas8 and 7
whistlepigger
Did you try clearing or erasing the disk first? Freenas gets easily confused if the disk you're using has had something else installed there before. So unless you are trying to import or preserve data, you might want to clear out your drive by using any disk utility (eg gparted livedisk).
ProtoSD
There's actually a question in the FAQ below in my signature about erasing your disk and how to do it. It can be done from the command line at the console.
B
Barak Michaeli
Guest
tenks....but i can't find it, can you give a direct link?
how can i do a JABUD in the raid?(it's only show miror)
