Problem creating Home Directory
Bob Goodwin
I have re-installed Freenas replacing 9.2.1.3 with 9.2.1.7. Before wiping everything clean and starting over I always had a directory /mnt/nasdata/ that would show up when I clicked on the Browse tab in the add user GUI. I no longer see that or anything but "/" in that window and I don't remember how that was created in the first Freenas install. I can't enter it there either. It just protests about not having a "mount point" when I try to save the added user. As a result I can't get beyond that point in configuring via the GUI.
I have moved the data I want to save to my NFS server and I believe I have wiped the data storage disks [mirrored] clean.
The computers run Fedora 64 bit Linux and I have selected UFS.
Any help appreciated,
Bob.
anodos
Sambassador
How your volume was created (is it a UFS mirror, single UFS disk)?
Is your volume accessible via the CLI? (i.e. cd /mnt/nasdata)
Post the following:
  • Hardware specs
  • Error messages from /var/log/messages
  • output of "df -ah"
  • output of "dmesg"
Bob Goodwin
The server runs scientific linux, an AMD procesor with 8g of ram. I can't even ssh into presently to get the spec's. The only connection to the server is via the Freenas browser.
From the GUI shell:
[root@freenas ~]# df -ah
Filesystem Size Used Avail Capacity Mounted on
/dev/ufs/FreeNASs1a 926M 703M 148M 83% /
devfs 1.0k 1.0k 0B 100% /dev
/dev/md0 4.6M 3.3M 902k 79% /etc
/dev/md1 823k 1.5k 756k 0% /mnt
/dev/md2 149M 13M 124M 9% /var
/dev/ufs/FreeNASs4 19M 733k 17M 4% /data
Dmesg but I think I am losing the first few lines in copy/paste:
ugen6.1: <ATI> at usbus6
uhub6: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus6
uhub4: 2 ports with 2 removable, self powered
uhub5: 4 ports with 4 removable, self powered
uhub0: 5 ports with 5 removable, self powered
uhub2: 5 ports with 5 removable, self powered
uhub6: 4 ports with 4 removable, self powered
uhub1: 5 ports with 5 removable, self powered
uhub3: 5 ports with 5 removable, self powered
ugen2.2: <Logitech> at usbus2
ums0: <Logitech USB-PS2 Trackball, class 0/0, rev 1.00/2.10, addr 2> on usbus2
ums0: 2 buttons and [XY] coordinates ID=0
ugen1.2: <PNY> at usbus1
umass0: <PNY USB 2.0 FD, class 0/0, rev 2.00/2.00, addr 2> on usbus1
umass0: SCSI over Bulk-Only; quirks = 0x4100
umass0:7:0:-1: Attached to scbus7
ada0 at ahcich2 bus 0 scbus2 target 0 lun 0
ada0: <WDC WD7500AARS-00Y5B1 80.00A80> ATA-8 SATA 2.x device
ada0: Serial Number WD-WCAV59544341
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 715404MB (1465149168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad8
ada1 at ahcich3 bus 0 scbus3 target 0 lun 0
ada1: <WDC WD7500AADS-00L5B1 01.01A01> ATA-8 SATA 2.x device
ada1: Serial Number WD-WCAU4A261683
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 715404MB (1465149168 512 byte sectors: 16H 63S/T 16383C)
ada1: Previously was known as ad10
da0 at umass-sim0 bus 0 scbus7 target 0 lun 0
da0: <PNY USB 2.0 FD 8.02> Removable Direct Access SCSI-0 device
cd0 at ahcich0 bus 0 scbus0 target 0 lun 0
cd0: <TSSTcorp DVD+-RW TS-H653A D300> Removable CD-ROM SCSI-0 device
cd0: 150.000MB/s transfers (SATA 1.x, UDMA2, ATAPI 12bytes, PIO 8192bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed
da0: Serial Number 1741020CB8D1156B
da0: 40.000MB/s transfers
da0: 3835MB (7856127 512 byte sectors: 255H 63S/T 489C)
da0: quirks=0x2<NO_6_BYTE>
SMP: AP CPU #1 Launched!
Timecounter "TSC" frequency 1600092240 Hz quality 800
GEOM_MIRROR: Device mirror/nasdata launched (2/2).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
vboxdrv: fAsync=0 offMin=0x81f offMax=0x136b
[root@freenas
cat /var/log/messages
Nov 6 10:01:43 freenas notifier: Starting lockd.
Nov 6 10:01:47 freenas notifier: rsyncd not running? (check /var/run/rsyncd.pid).
Nov 6 10:01:47 freenas notifier: Starting rsyncd.
Nov 6 10:01:52 freenas notifier: proftpd not running?
Nov 6 10:01:52 freenas notifier: Starting proftpd.
Nov 6 10:01:54 freenas proftpd[4995]: 127.0.0.1 - ProFTPD 1.3.4d (maint) (built Thu Aug 7 2014 00:42:49 UTC) standalone mode STARTU
P
Nov 6 10:02:04 freenas notifier: netatalk not running?
Nov 6 10:02:07 freenas notifier: Starting netatalk.
Nov 6 10:02:07 freenas netatalk[5153]: Netatalk AFP server starting
Nov 6 10:02:07 freenas cnid_metad[5156]: CNID Server listening on localhost:4700
Nov 6 10:02:11 freenas afpd[5155]: Netatalk AFP/TCP listening on 192.168.1.48:548
Nov 6 11:31:56 freenas mountd[4564]: mount request from 192.168.1.10 for non existent path /mnt/nasdata
Nov 6 11:31:56 freenas mountd[4564]: mount request denied from 192.168.1.10 for /mnt/nasdata
Nov 6 12:00:49 freenas mountd[4564]: export request succeeded from 192.168.1.10
Nov 6 12:00:59 freenas mountd[4564]: mount request from 192.168.1.10 for non existent path /SRVR1
Nov 6 12:00:59 freenas mountd[4564]: mount request denied from 192.168.1.10 for /SRVR1
Nov 6 12:02:50 freenas mountd[4564]: mount request from 192.168.1.10 for non existent path /mnt/nasdata
Nov 6 12:02:50 freenas mountd[4564]: mount request denied from 192.168.1.10 for /mnt/nasdata
Nov 6 12:11:27 freenas notifier: Will not 'stop' rtsold because rtsold_enable is NO.
Nov 6 12:11:27 freenas notifier: Setting hostuuid: 31433646-3635-4337-3745-3833ffffffff.
Nov 6 12:11:27 freenas notifier: Setting hostid: 0x67129c4e.
Nov 6 12:11:28 freenas notifier: dhclient already running? (pid=1005).
Nov 6 12:11:30 freenas notifier: Starting Network: lo0 re0 ipfw0.
Nov 6 12:11:30 freenas notifier: lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
Nov 6 12:11:30 freenas notifier: options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
Nov 6 12:11:30 freenas notifier: inet6 ::1 prefixlen 128
Nov 6 12:11:30 freenas notifier: inet6 fe80::1%lo0 prefixlen 64 scopeid 0xa
Nov 6 12:11:30 freenas notifier: inet 127.0.0.1 netmask 0xff000000
Nov 6 12:11:30 freenas notifier: nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
Nov 6 12:11:30 freenas notifier: re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
Nov 6 12:11:30 freenas notifier: options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
Nov 6 12:11:30 freenas notifier: ether 1c:6f:65:c7:7e:83
Nov 6 12:11:30 freenas notifier: inet 192.168.1.48 netmask 0xffffff00 broadcast 192.168.1.255
Nov 6 12:11:30 freenas notifier: nd6 options=9<PERFORMNUD,IFDISABLED>
Nov 6 12:11:30 freenas notifier: media: Ethernet autoselect (1000baseT <full-duplex>)
Nov 6 12:11:30 freenas notifier: status: active
Nov 6 12:11:30 freenas notifier: ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
Nov 6 12:11:31 freenas notifier: route: writing to routing socket: File exists
Nov 6 12:11:31 freenas notifier: add net fe80::: gateway ::1 fib 0: route already in table
Nov 6 12:11:31 freenas notifier: add net ff02::: gateway ::1 fib 0: route already in table
Nov 6 12:11:31 freenas notifier: add net ::ffff:0.0.0.0: gateway ::1 fib 0: route already in table
Nov 6 12:11:31 freenas notifier: add net ::0.0.0.0: gateway ::1 fib 0: route already in table
Nov 6 12:11:32 freenas notifier: Will not 'start' rtsold because rtsold_enable is NO.
[root@freenas ~]#
Bob Goodwin
For the last six months I've had a Freenas server that ran well but I decided to manipulate the dirctories from my linux file manager. When I found that would not work I tried to restore what I had before via the file manager, things got worse!
I decided to reinstall the Freenas stuff. I saved the files to my nfs server and I think I cleaned everything out of the old Freenas and now I am re-installing the server with a later version. It seems that should be simple enough but I am having problems.
As I said the only LAN connection to the server is via the Freenas GUI. I set the ssh service to ON but it rejects my password, although the password works to run the GUI from the browser?
From the Freenas GUI:
System Information
Hostname freenas.local
Build FreeNAS-9.2.1.7-RELEASE-x64 (fdbe9a0)
Platform AMD E-350 Processor
Memory 7784MB
Have you enabled "login as root with password" in the SSH settings? You may also need to enable password authentication.
Bob Goodwin
"Have you enabled "login as root with password" in the SSH settings? You may also need to enable password authentication."
Where do I find these settings? I've gone through the GUI set-up screen a couple of times and don't see them, thought it might be under "services" but if it is I am missing it.
I also connected a keyboard and monitor to the server, all that offers is item 7 which forces a rest of the webgui password. I dunno why I'm having so much trouble, last spring I was able to get Freenas running on two different boxes with a lot less difficulty!
Can it be something remaining on the hardrives. If nothing else, I can install Fedora 20 and wipe them clean and start over. I would like to get this working ...
Thanks
Bob
Bob Goodwin
I did not realize there is a menu under the wrench icon? Duh!
Ok, so now I can ssh into the server. Need to see what else I can do under "Services."
Thank you.
Bob Goodwin
However although I can ssh into the server 192.168.1.48, I can not mount it:
[root@box7 bobg]# mount 192.168.1.48:/mnt/nasdata/bobg /mnt/box48/
mount.nfs: access denied by server while mounting 192.168.1.48:/mnt/nasdata/bobg
I can't configure Freenas until it is mounted. Access denied by server would seem to make it a Freenas problem?
Or is there something wrong with my mount command?
I have the line:
192.168.1.48:/mnt/nasdata/bobg /mnt/box48/ nfs default 0 0
in /etc/fstab. And that has always worked until now.
Bob
Bob Goodwin
I still do not have a working Freenas server. Yesterday I tried installing 9.3b, gave up on that as an even bigger effort.
I then removed the 9.3b thumb drive and plugged in one with 9.2.1.8. That almost works, except for ssh, without which I can't load my data into the server. Trying to access from either of two Fedora boxes, F-20 and F-21a, produces the same result:
[root@box10 bobg]# ssh bobg@192.168.1.48
ssh_exchange_identification: Connection closed by remote host
Can anyone tell me how to correct this?
Bob
