Problem booting VM after upgrade to 11.3: VM waits for VNC to connect
vafk
After upgrade to 11.3 I have the following problem:
My VM with pi-hole on Ubuntu 18.04.4 with autostart marked does not start unless I connect with VNC and then the VM starts to boot.
I checked this report https://redmine.ixsystems.com/issues/27288 and made sure /boot/efi/EFI/BOOT/bootx64.efi is in the place which is (and was) the case.
I also checked this https://www.ixsystems.com/community/threads/howto-how-to-boot-linux-vms-using-uefi.54039/ and unchecked "Delay VM boot until VMC connects" which was selected by default. But this un-setting has no effect so I need to connect to VNC to make the VM boot.
Anyone having the same problem and possibly a solution?
