The situation is given as here:
The server is my NAS box which has a free 2nd ethernet port, the printer is physically close (on top of the server).
Furthermore my switch ports are all occupied. My problem is if I try to access my printer from PC there is no static route to my server from my switch.
I can not add any routes in the switch since it is one I was provided.
I had the following idea to give it some address in the 192.168.1.x subnet, and then forward that ip to my printer (via a route?) in freenas.
One problem that I see, is that the switch once again doesn't know that ip should also be sent to 192.168.1.3...
Lastly, I have no idea how to do this... So your help guys will be appreciated.
