Hi all,
I'm new to the forums and new to the FreeNAS. Until now I have been using OpenBSD with 8 stand alone drives as my storage. It does what it does good enough, mostly for media files and some personal stuff. I have a script that goes throguh all the drives and collects all media symlinks and that's exported as a Samba share, but I always wanted to have some more reliability and a single pool for my media. I was eyeing zfs for some time and finally got a chance to buy a cheap, unpacked PE T110 II. I didn't have much time to look into details and since it was cheap I went for it:
- Intel Xeon E3-1230 v2
- single stick of 8GB 1600MHz ECC DDR3, max of 32GB (4x 8GB)
- 4x 3.5" HDD trays, 2x 5.25" device bays
- motherboard with 5x internal SATA, 1x eSATA, and a H200 (LSI 9211-8i) included with the config
I re-flashed H200 into IT mode, put in some drives and did a test run with FreeNAS 9.10 - it works, all is good :) But, my original plan was to fill it woth 7-8x 4TB drives. I've got some nice Seagate ES 3 drives, 7 of them, and one HGST Deskstar 4TB. And here in lies my problem - how do I fill up this little baby with 7-8 drives? I was hoping that I coould take out the control panel and place a in 4-in-3 drive cage that I have handy into the device bays but that won't be possible without modifications.
I came up with following options. Please let me know what do you think or if there's another approach that I missed:
I also thought about gutting the server and placing to mobo in another case but it turns out it's mirrored desing - the expansion card slots are to the right of the back panel, not to the left as normal mobos are built.
I would really appreciate any input. Thanks!
- rip out the control panel and cut the device bay cage to allow the 4-in-3 drive cage to be used. I'd lose my warranty so not to keen on this
- use 3-in-2 drive cage instead. AFAIK, all of the models I looked at use some kind of backplane, as opposed to 4-in-3 variation :(
- use external 4 drive bay and connect using eSATA. Is this recommended? How about performance? Will SMART work?
- suspend two HDDs in the device bay, and place down on the bottom of the case 1-2 HDDs (one would should fit, not so sure about the other one).
