Rod_
- Jul 18, 2021
Someone was able to install VMs on TrueNAS-12.0-U4.1 using PowerEdge 2950 (2x Xeon E5430@2.66 GHz) BIOS Version is 2.7.0, BIOS is quite simple Virtualization is enabled. I've already installed ESXi, Hyper-V without problems.
Any information is welcome.
Error: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 137, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self, File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1198, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 484, in create rv = await self.middleware._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1198, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 973, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/vm.py", line 1283, in do_create verrors.check() File "/usr/local/lib/python3.9/site-packages/middlewared/service_exception.py", line 62, in check raise self middlewared.service_exception.ValidationErrors: [EINVAL] vm_create: This system does not support virtualization.
