Hey All -
I seem to be encountering an issue (maybe its a known limitation) but I can't get startup scripts to work on an encrypted drive - regardless of whether or not they are set to Pre-Init or Post Init. I suspect it's because the system can't locate the script (which resides on a mounted pool) because the pool isn't unlocked yet with a passphrase.
I read elsewhere to move scripts to the /data partition and that it should survive any system software updates - is that correct?
Thanks
Thanks
