fyboqyovjy
- Jul 6, 2020
I've read the documentation about encrypted pools in FreeNAS. It says:
This is my current setup:
I have Proxmox on my server and FreeNAS is a VM on it.
The boot device and also the VM image storage is a mirror with two self encrypting SSDs.
So if I want to boot the server and run a VM, I already have to type a password to decrypt the boot device.
For FreeNAS I passthrough a PCIe HBA. Then I created an encrypted pool on it.
Now I'm not sure if it makes sense to add a passphrase to this encrypted pool, or not?
The pool will unlock automatically if I start the FreeNAS VM.
But to be able to do that, I have to type a password anyway.
What do you think?
Will I gain anything if I add a passphrase to manually unlock the encrypted pools?
Also:
Isn't that ridiculous? Or is there something I didn't understand? Should I use the boot device as system dataset in this case?
Encrypted pools that have no passphrase are unlocked at startup. Pools with a passphrase remain locked until a user enters the passphrase to unlock them.
What do you think?
Also:
In my case the system dataset is the encrypted pool. Where's the logic to store the encryption key on the encrypted pool?FreeNAS® generates a randomized encryption key whenever a new encrypted pool is created. This key is stored in the system dataset. It is the primary key used to unlock the pool each time the system boots.
