Possible to disable L2ARC for a volume?
geekmaster64
Hey there,
Is it possible to disable the L2ARC or ARC for a specific volume? For example, I have a volume that is strictly media, whereas other volumes are VM's or other's that would benefit from the L2ARC. I did several searches on the forums and wasn't able to find anything.
Thanks!
Chris Moore
Hey there,
Thanks!
It is my understanding that a L2ARC is applied to the entire pool. If you want a portion of the storage to have one performance characteristic and another portion of the storage to have a different characteristic, they need to be separate pools. For exapmple, in my primary storage server, I have one pool that is made of 2 RAIDz2 vdevs (12 drives total) and I use that for mass storage of regular files and media such as movies. I have another pool that is made of 8 mirror vdevs (16 drives) and I use that for my iSCSI storage for fast access, near line speed on 10Gb networking. One pool is for slow storage and the other is for fast storage and they are configured totally different because the performance is dictated by the hardware. Still, adding a SLOG or L2ARC device to a pool is a pool wide setting, not done per dataset.
geekmaster64
Thank you! I was hoping I wouldn't have to do that as I have a limited number of drives. I appreciate your quick and accurate response Chris :)
Hey there,
Thanks!
It should be possible to keep some datasets or zvols from using the L2ARC by setting their secondarycache property to ‘none’.
Or setting it to ‘metadata’ to keep file data from the cache but have metadata cached.
The primarycache property controls the ARC.
Paul
geekmaster64
Paul
Really? That would be extremely useful. In other storage systems like Nimble, it's controlled by a per volume basis which made it really handy. I'll have to do some more reading around those controls.
