450W should be sufficient for 6 drives. I chose the option that is closest to my setup:
2) For an E3-1230v3 (32-98W board+CPU, 12W memory):
- 5-6 Drives: 360W peak, 132W idle -> SeaSonic G-450
You're recommending a SeaSonic G-450 and I have a Corsair CX 450.
I think that's a poor pick, not at all close to your setup.  Your host is described as
HP Z420 Workstation Motherboard
8x8GB Micron DDR3 ECC 1800MHz memory
Intel Xeon E5 2660v2 10-core CPU
240GB Crucial SSD as boot drive
6x12TB WD Ultrastar DC HC520 hard drives set up as Z2 array
Radeon HD7770 1GB graphics card for console access
The Z420 is known to be a piggy system, as
documented in various places.  A workstation grade mainboard is going to burn more watts than the low end server grade board needed for an E3-1230v3, and the E5-2660v2 is a 95W TDP part compared to the much more efficient E3-1230v3 which maxxes out at 80W and doesn't usually use it all.  You also have double the number of DIMM's of the 1230 system, and they're probably not the lower power UDIMM's included in the 1230 estimate (~= 12W) but more like 4 or 5 watts per DIMM (yours ~= 32-40W).  Using the lower density RDIMM's burns watts.
Your system is much closer to the option 3) I precalculated, except you've got more DIMM's than I anticipated AND you have a Radeon GPU in there AND you have a possibly piggier workstation board in there (I haven't load tested a Z420 so I have no specific numbers).  The Radeon idles at 80W and tops out at 106W and I think you should add at least 15W for RDIMM.  Circling back around to the precalculated numbers,
3) For an E5-1620v3 (speculative: 70-210W board+CPU, 24W memory):
- 1-2 Drives: 319W peak, 125W idle -> SeaSonic G-450
- 3-4 Drives: 389W peak, 141W idle -> SeaSonic G-550
- 5-6 Drives: 484W peak, 182W idle -> SeaSonic G-650 or X-650
- 7-8 Drives: 554W peak, 198W idle -> SeaSonic G-750 or X-750
- 9-10 Drives: 639W peak, 229W idle -> SeaSonic X-850
- 11-12 Drives: 709W peak, 245W idle -> SeaSonic X-850 or X-1050
But I think for your 6 drive scenario with the Radeon and RDIMM adjustment, I would guess more like 610W peak, 277W idle, which puts you around needing an 800W PSU to reliably handle the load.  Now of course this is still speculative, but it is based on real world observations of real parts, just not YOUR specific parts.
