DrunkenPeleg
 - Apr 25, 2019
Persistent little issue I've got here. A storage pool bugs out and becomes unavailable randomly. This started happening about two weeks ago; pool would go out every 6-10 hours. A reboot brought the pool back up, but it had to be a power cycle, since the restart failed due to a hanging process.
OK, so let's get started.
Here is an example of what happens with the pool:
At this point, I can't do anything with the pool since it just gives me the 'I/O is currently suspended' error
So, I initiate a reboot (have tried regular shut down as well). After some time the process hangs- here's the tail end of things:
Now, I partly guess that the jails are preventing shutdown as a result of mount points pointing to the affected pool.
When I was having this issue two weeks ago, it was "resolved" after checking all cable connections, reseating the controller card and running a scrub. I thought it was probably just a loose connection somewhere as I had recently changed out a drive and probably jiggled something loose somewhere.
As you can see in the logs above, my attempts to run a scrub now are being foiled by the pool going out before the scrub can finish.
I think the restart/shutdown issue is secondary to whatever is going on with the pool. I should note that prior to this occurring again, there were no read/write errors, and SMART tests did not return any issues.
Should I chalk this up to bad cables, or perhaps the controller card? What's my best option to narrow this down?
root@freenas[~]# zpool status -v POOL4
  pool: POOL4
 state: UNAVAIL
status: One or more devices are faulted in response to IO failures.
action: Make sure the affected devices are connected, then run 'zpool clear'.
   see: http://illumos.org/msg/ZFS-8000-JQ
  scan: scrub in progress since Mon Aug 10 12:11:15 2020
        5.24T scanned at 1.57G/s, 2.35T issued at 722M/s, 30.3T total
        0 repaired, 7.75% done, 0 days 11:17:04 to go
        NAME                      STATE     READ WRITE CKSUM
        POOL4                     UNAVAIL      0     0     0
          raidz2-0                UNAVAIL     44     0     0
            12611917014333540652  REMOVED      0     0     0  was /dev/gptid/9feee305-50eb-11ea-ad9a-002590343322
            1567844855632180418   REMOVED      0     0     0  was /dev/gptid/adf3da24-50eb-11ea-ad9a-002590343322
            10092631138471912601  REMOVED      0     0     0  was /dev/gptid/af868d3e-af7c-11ea-800a-002590343322
            12748854986319037125  REMOVED      0     0     0  was /dev/gptid/c9b0f525-50eb-11ea-ad9a-002590343322
            6683381636331138817   REMOVED      0     0     0  was /dev/gptid/d7735d16-50eb-11ea-ad9a-002590343322
            7872409557343776049   REMOVED      0     0     0  was /dev/gptid/43c07d3d-caf8-11ea-969f-002590343322
            8424755186125633080   REMOVED      0     0     0  was /dev/gptid/e689752c-50eb-11ea-ad9a-002590343322
            10321425597778855069  REMOVED      0     0     0  was /dev/gptid/f46ad081-50eb-11ea-ad9a-002590343322
            11260363593274240624  REMOVED      0     0     0  was /dev/gptid/022be270-50ec-11ea-ad9a-002590343322
            6997537682382531171   REMOVED      0     0     0  was /dev/gptid/10ab5145-50ec-11ea-ad9a-002590343322
        <metadata>:<0x0>
        <metadata>:<0x1>
        <metadata>:<0x48>
        POOL4:<0x13003>
        POOL4:<0x82d2>At this point, I can't do anything with the pool since it just gives me the 'I/O is currently suspended' error
Stopping ntpd. Waiting for PIDS: 1672, 1672. Shutting down local daemons:. Stopping lockd. Waiting for PIDS: 1628. Stopping statd. Waiting for PIDS: 1625. Stopping nfsd. Waiting for PIDS: 1616 1617. Stopping mountd. Waiting for PIDS: 1610. Stopping watchdogd. Waiting for PIDS: 1550. Stopping rpcbind. Waiting for PIDS: 1395. Writing entropy file:. Writing early boot entropy file:. Aug 10 14:23:46 freenas init: timeout expired for /etc/rc.shutdown: Interrupted system call: going to single user mode Aug 10 14:23:46 freenas init: timeout expired for /etc/rc.shutdown: Interrupted system call: going to single user mode Aug 10 14:24:06 init: some processes would not die: ps axl advised
