Pool showing higher usage than zvol size
Eria211
I have created a pool with 2 vdevs of 6 drives, each drive is 6TiB.
I created a 15TiB zvol with 16kb blocks on the pool and the pool read ~15.2TB of useage which is fine
I wrote approximately 6.5TB to the zvol and took some snapshots
Shortly after my transfer was complete, I lost a disk, just totally died. So I removed the disk, added a spare I had bought, and resilvered, all seemed to be well
Unfortunately my pool now reads:
HEALTHY
: 21.75 TiB (52%) Used / 20.19 TiB Free
Where has the excess space gone?
I erased the previously taken snapshots as they were just for testing while the data was transfering and started a schedule of hourly snapshots
NAME                                                         USED  AVAIL  REFER  MOUNTPOINT
freenas-boot                                                1.00G  91.5G    23K  none
freenas-boot/ROOT                                           1023M  91.5G    23K  none
freenas-boot/ROOT/Initial-Install                              1K  91.5G  1020M  legacy
freenas-boot/ROOT/default                                   1023M  91.5G  1020M  legacy
store                                                   21.8T  20.2T   176K  /mnt/store
store/.system                                           36.5M  20.2T   192K  legacy
store/.system/configs-ee21f3733ab34d689aed5079e9ac663b  1.67M  20.2T  1.67M  legacy
store/.system/cores                                      799K  20.2T   799K  legacy
store/.system/rrd-ee21f3733ab34d689aed5079e9ac663b      32.7M  20.2T  32.7M  legacy
store/.system/samba4                                     216K  20.2T   216K  legacy
store/.system/syslog-ee21f3733ab34d689aed5079e9ac663b    767K  20.2T   767K  legacy
store/.system/webui                                      176K  20.2T   176K  legacy
store/test2                                        256K  20.2T   256K  /mnt/store/test2
store/test1                                        256K  20.2T   256K  /mnt/store/test1
store/main                                          21.8T  35.4T  6.52T  -
NAME           SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP  HEALTH  ALTROOT
freenas-boot  95.5G  1.00G  94.5G        -         -     0%     1%  1.00x  ONLINE  -
store       65T  9.79T  55.2T        -         -     0%    15%  1.00x  ONLINE  /mnt
freenas-boot/ROOT/default@2020-05-11-10:28:53  3.03M      -  1020M  -
store/main@auto-2020-05-19_17-00           0      -  6.52T  -
store/main@auto-2020-05-19_18-00           0      -  6.52T  -
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:00:03 with 0 errors on Mon May 18 03:45:03 2020
    freenas-boot  ONLINE       0     0     0
      mirror-0  ONLINE       0     0     0
        ada0p2  ONLINE       0     0     0
        ada1p2  ONLINE       0     0     0
errors: No known data errors
  pool: store
 state: ONLINE
  scan: scrub in progress since Tue May 19 17:55:14 2020
    3.90T scanned at 1.59G/s, 2.71T issued at 1.11G/s, 9.79T total
    0 repaired, 27.67% done, 0 days 01:49:14 to go
    NAME                                                STATE     READ WRITE CKSUM
    store                                           ONLINE       0     0     0
      raidz2-0                                          ONLINE       0     0     0
        gptid/9b773def-99da-11ea-ad82-f4f26d034739.eli  ONLINE       0     0     0
        gptid/f89b876d-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
        gptid/f771128b-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
        gptid/f79a743e-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
        gptid/f8e7394a-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
        gptid/f939a350-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
      raidz2-1                                          ONLINE       0     0     0
        gptid/f8455b43-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
        gptid/f7d29c3e-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
        gptid/f8baee36-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
        gptid/f792359c-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
        gptid/f8de70e8-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
        gptid/f9169dbd-9388-11ea-ab8d-f4f26d034739.eli  ONLINE       0     0     0
Eria211
when I view go to Storage \ Pools \ Edit Zvol in the GUI and view the size set on the zvol, it is 15TiB but the status page insists it is over 20TB
I hoped a scrub would release the space, the scrub finished and did not change matters at all.
The scrub reported that there was not 20+TB of data on the drives, it agreed with the value given by zpool list (the value given by zpool list is lower but I believe this doesn't have the parity usage included?)
