rodfantana
 - Jun 10, 2017
I have a RAIDZ volume comprised of 4 disks.  One of them is showing up as FAULTED (too many errors), but the whole volume is marked as UNAVAIL (insufficient replicas).  That's from 'zpool status -x'.    Shouldn't volume be in the DEGRADED mode with 3 out of 4 disks marked as ONLINE?
The data on some of the shares is still accessible. I'm assuming the vmware_block and the .exe mentioned below are hosed. I'm OK with that, I have backups of vmware_block; exe's can be dismissed.
I have a replacement disk that i can plug in. Will that rebuild the array w/o any data loss?
root@xxxxx~ # zpool status -x
pool: vol1
state: UNAVAIL
status: One or more devices are faulted in response to persistent errors. There are insufficient replicas for the pool to
continue functioning.
action: Destroy and re-create the pool from a backup source. Manually marking the device
repaired using 'zpool clear' may allow some data to be recovered.
scan: resilvered 0B in 00:00:01 with 0 errors on Sun Sep 25 10:09:48 2022
NAME STATE READ WRITE CKSUM
vol1 UNAVAIL 0 0 0 insufficient replicas
gptid/22fa4130-4e69-11e7-80ba-000c29c4efeb FAULTED 5 0 0 too many errors
gptid/23b12f8a-4e69-11e7-80ba-000c29c4efeb ONLINE 0 0 0
gptid/2466f5df-4e69-11e7-80ba-000c29c4efeb ONLINE 0 0 0
gptid/25148b95-4e69-11e7-80ba-000c29c4efeb ONLINE 0 0 0
errors: 5 data errors, use '-v' for a list
root@xxxxxx:~ #
root@xxxxxx:~ # zpool status -v vol1
pool: vol1
state: UNAVAIL
/var/db/system/syslog-fe5739137b3643d3a6327c8c1d9b1a34/log/middlewared.log
/var/db/system/rrd-fe5739137b3643d3a6327c8c1d9b1a34/localhost/interface-vmx0/if_errors.rrd
/mnt/vol1/apps/7z1900-x64.exe
/mnt/vol1/apps/VeraCrypt Setup 1.21.exe
vol1/vmware_block:<0x1>
root@xxxxx:~ #
