On Alert Settings page, at "Pool Status Is Not Healthy" and "Boot Pool Is Not Healthy" I've set "Set frequency" to HOURLY,
but there is only one alert email sent.
I have a mirrored boot pool (2 SSD disks) and a mirrored data pool (2 WD HDD disks). First I detached one boot
disk (in power off state), then I received one alert email. A waited for a couple of hours, nothing happened.
Then I detached one data disk (also in power off state). After booting the system, I received another alert email, at
13:00 (not at boot time), stating as new alert the missing WD HDD disk, mentioning at "Current alerts" the degraded
boot pool.
And that was it. No more alert emails. Am I missing the right setting?
I don't know if it means something, that the Pool state is Degraded part contains the disk model ans serial number
"is UNAVAIL", while at the "Boot pool status is Degraded" part there is no disk mentioned.
boot pool.
New alerts: * Pool pool state is DEGRADED: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. The following devices are not healthy: Disk WDC WD5000BEVT-26A0RT0 WD-WXG1A5081101 is UNAVAIL Current alerts: * Pool pool state is DEGRADED: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. The following devices are not healthy: Disk WDC WD5000BEVT-26A0RT0 WD-WXG1A5081101 is UNAVAIL * Boot pool status is DEGRADED: One or more devices could not be used because the label is missing or invalid. Sufficient replicas exist for the pool to continue functioning in a degraded state..
