Pool out of space - but it's empty
FreeNAS-11.3-U1
I have a "scratch" pool (temporary space, only used as the download location before it's moved to a Media pool) that appears to be full but doesn't have any content in it.
Below I'm using 12.9GB because I've paused a download. But it's no where near the 900GB capacity of the pool.
I thought maybe it was a problem of snapshots filling the drive but when I go in FreeNAS/Storage/Snapshot and filter by "Scratch" nothing shows and SSH confirms:
zpool status (for Scratch):
zpool get all Scratch
zpool list:
zfs list Scratch:
df -h Scratch:
And I've attached a
zfs get all
log to this post.
I'm just not seeing the problem because I don't see any space being used on the Scratch pool. Any ideas?
thank you for looking.
  • ZFS GET ALL.txt
Snapshots... they take up space (particularly for deleted files).
How would I go about finding that content? When I "ls" into /mnt/Scratch/.zfs/snapshot nothing shows. Do the deleted items snapshots reside in a folder that root can't see?
I'm not on a device where I can spell it out for you now, but searching zfs set visible should show up something which may populate that structure you can see.
Also, look at the GUI under Storage | Snapshots
Oh yeah - zfs is visible; did that a few days ago. GUI doesn't show any snapshots for "Scratch" (same as what SSH shows - notta)
Thx
Then maybe it's a dataset-directory collision.
Are you certain there are no child datasets of Scratch?
Restart your downloader jail.
I am also impacted by that bug where items deleted within the downloader jail don't register as deleted on the host and the used space isn't decremented until the jail is restarted... I haven't given it a lot of attention recently, but it was a reported bug perhaps more than a year ago which was supposed to be fixed in a version that's probably already out... seems not fixed to me.
Restarting the jail solved it. Thank you!
You'll need to periodically do that to stop the jail/pool thinking it's out of space until the bug gets sorted... you may wait a while for that.
Yeah. At least I now know what's going on. I appreciate your help over those few days. Have a good one.
