Pool is FAULTED (metadata is corrupted) and 1 Unassigned Disks
munghauzen
while TrueNAS (SCALE-22.12.4.2) was running, a couple of disks failed and the pool became inaccessible. NAS is running in a VMware based virtual machine, RAID is hardwired. I realize that this configuration is wrong, but this is the situation. After powering up again, the pool became unavailable and 1 disk was not assigned. Attempts to import the pool were unsuccessful.
I can try to mount the disk in another virtual machine, or recreate the pool without removing the disk. Will I not lose data with these operations? 25Tb has nowhere to backup.
root@truenas[~]# zpool import
   pool: basic
  state: FAULTED
status: The pool metadata is corrupted.
 action: The pool cannot be imported due to damaged devices or data.
    The pool may be active on another system, but can be imported using
    the '-f' flag.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-72
    basic                                   FAULTED  corrupted data
      0a4b9dbb-323a-4954-b7f2-14eaead24ef1  ONLINE
root@truenas[~]# zpool import -f basic
cannot import 'basic': insufficient replicas
    Destroy and re-create the pool from
    a backup source.
root@truenas[~]# zpool status -v
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:43 with 0 errors on Mon Jan  1 03:45:45 2024
      sda3      ONLINE       0     0     0
errors: No known data errors
  pool: fast
 state: ONLINE
  scan: scrub repaired 0B in 00:01:07 with 0 errors on Sun Dec 24 00:01:08 2023
    NAME                                    STATE     READ WRITE CKSUM
    fast                                    ONLINE       0     0     0
      555b047f-04f7-4643-afa9-028679b8dd84  ONLINE       0     0     0
  pool: nvme
 state: ONLINE
  scan: scrub repaired 0B in 00:07:49 with 0 errors on Sun Dec 24 00:07:50 2023
    nvme                                    ONLINE       0     0     0
      c435c64d-d7d7-4930-b903-501f136827d4  ONLINE       0     0     0
  pool: unimportant
 state: ONLINE
    corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
    entire pool from backup.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
  scan: scrub repaired 0B in 11:24:09 with 0 errors on Sun Apr 30 11:24:10 2023
    unimportant                             ONLINE       0     0     0
      3fe7226e-62bf-44b0-a5ee-7321999c0691  ONLINE       0     0     8
        unimportant/v2:<0x0>
   pool: basic
  state: FAULTED
    the '-f' flag.
root@truenas[~]# zpool status -v basic
cannot open 'basic': no such pool
    a backup source.
root@truenas[~]# zpool import basic
    a backup source.
  pool: boot-pool
 state: ONLINE
      sda3      ONLINE       0     0     0
  pool: fast
 state: ONLINE
    fast                                    ONLINE       0     0     0
  pool: nvme
 state: ONLINE
    nvme                                    ONLINE       0     0     0
  pool: unimportant
 state: ONLINE
      3fe7226e-62bf-44b0-a5ee-7321999c0691  ONLINE       0     0    12
errors: 1 data errors, use '-v' for a list
root@truenas[~]# zpool status -м
invalid option '�'
usage:
    status [-c [script1,script2,...]] [-igLpPstvxD]  [-T d|u] [pool] ...
        [interval [count]]
You have a single-disk pool... because of this:
If that "single disk" is corrupt, you have nowhere to recover from with ZFS.
If the data is important to you, you will need to use a ZFS recovery tool like Klennet. (although with your setup, even that will be difficult). Sorry to say that you will probably lose your data.
Next time, you should follow the guidance for a virtualized instance.
HoneyBadger
actually does care
Administrator
How do I know if a disk is corrupted or not?
The zpool import gave you this result:
You can attempt a zpool import -fFn basic (little "f" for "force import", big "F" being "Force Recovery", and little "n" for "no-op" or "don't actually do the import, just display if it's possible")
However, based on the initial description of
If several disks underpinning a hardware RAID failed, recovery will be determined first by the ability of that hardware RAID to survive that failure. Assuming that the virtual RAID volume is viable, you may be able to "rewind" the ZFS transactions, but may lose some data from this.
munghauzen
I tried running this command. The system thinks for a couple of seconds and gives no response
root@truenas[~]# zpool import -fFn basic
root@truenas[~]#
I restarted the raid with the same disks. Other data and even a different pool on that disk - started without problems. It remains unclear why this pool didn't start, possibly due to corruption....
HoneyBadger
actually does care
Administrator
No news is good news - it didn't throw a panic or an error at you. Try removing the n and sending in just zpool import -fF basic - follow that with zpool status -v if it appears to import.
munghauzen
According to the console, the pool is damaged, not the disk. How connected are the pool and the disk? Can I try mounting the disk in a new pool with the same name on a clean NAS without losing data?
HoneyBadger
actually does care
Administrator
The pool is built on top of the disk - you'll have the same results on a new install of TrueNAS.
munghauzen
Похоже на плохие новости :(
root@truenas[~]# zpool import -fF basic
    a backup source.
It's also very sad
HoneyBadger
actually does care
Administrator
    a backup source.
It's also very sad
Try the following combination:
echo 0 >> /sys/module/zfs/parameters/spa_load_verify_data
echo 0 >> /sys/module/zfs/parameters/spa_load_verify_metadata
zpool import -fFX basic
The first two lines disable verification of data and metadata. Yes, this is normally a really bad thing to do, but when rewinding pools to earlier transactions, the verification can take "hours to days" on large pools. If this succeeds, check the status output.
munghauzen
It didn't work
root@truenas[~]# echo 0 >> /sys/module/zfs/parameters/spa_load_verify_data
root@truenas[~]# echo 0 >> /sys/module/zfs/parameters/spa_load_verify_metadata
root@truenas[~]# zpool import -fFX basic
cannot import 'basic': one or more devices is currently unavailable
The other import options didn't help either. But the devices are available
