viniciusferrao
- Mar 30, 2013
Hello, I've a pool that three disks aren't showing up as member of the pool on the GUI, here's the outputs on the terminal:
And the same on the web interface:
You can see on the first image that the disk icon is missing, also on the second one the pool is marked as N/A.
I don't know why this is this way.
Thanks,
PS: Shrinked down version of fdisk -l:
pool: pool0 state: ONLINE scan: resilvered 127G in 00:48:19 with 0 errors on Tue Jun 6 17:35:44 2023 config: NAME STATE READ WRITE CKSUM pool0 ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 06ef7774-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 09ff9347-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 08bc2b61-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 0a3eb6cc-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 09f13b84-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 09e1fc7e-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 0a1f949a-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 06fa51c9-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 0a0f7341-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 0a2f088a-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 09d246a8-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 b7af91d7-fd19-4870-b5fb-c8b377bda21d ONLINE 0 0 0 cache 068fb4d8-3adb-11ed-8896-0cc47a859fe4 ONLINE 0 0 0 errors: No known data errors
Thanks,
Disk /dev/nvme0n1: 372.61 GiB, 400088457216 bytes, 781422768 sectors Disk /dev/sdc: 59.63 GiB, 64023257088 bytes, 125045424 sectors Disk /dev/sdb: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdd: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdk: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdi: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdg: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdm: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdh: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdl: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdj: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdn: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sde: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdf: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdo: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdp: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdv: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdt: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sds: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdw: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdr: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdu: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdz: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdx: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdy: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sdq: 5.46 TiB, 6001175126016 bytes, 11721045168 sectors Disk /dev/sda: 59.63 GiB, 64023257088 bytes, 125045424 sectors Disk /dev/md127: 2 GiB, 2144337920 bytes, 4188160 sectors Disk /dev/md126: 2 GiB, 2144337920 bytes, 4188160 sectors Disk /dev/md125: 2 GiB, 2144337920 bytes, 4188160 sectors Disk /dev/mapper/md127: 2 GiB, 2144337920 bytes, 4188160 sectors Disk /dev/mapper/md126: 2 GiB, 2144337920 bytes, 4188160 sectors Disk /dev/mapper/md125: 2 GiB, 2144337920 bytes, 4188160 sectors
