Martin Jones
- Feb 9, 2016
Build FreeNAS-11.1-U2
Platform Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
Memory 16311MB
4x 3TB WDRED's Raid Z2-0
OK I'll start by saying that "One is born every minute" and I'm the one. What does every moderator say? Don't do anything you don't understand!!!!!!!!!! welcome to my world!
This started as a simple boot failure, but recreated and replaced the boot drive. Then I made the mistake. Took the additional iso drive out of the USB port put it on the table and rebooted the system. I then tried to mirror the boot before importing the pool. Unfortunately I'd forgotten to add the additional flash drive and without realising, created the mirror from one of my pool disks ADA0. So when I imported the pool, of course, got the following error;
CRITICAL: March 28, 2018, 8:32 a.m. - The volume Systems state is DEGRADED: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state.
SO, I went looking for how to replace failing drive, went to Volume Status expecting to be able to offline the drive but no offline button existed. Tried to replace the disk and got this error;
Replacing disk 10426849769521457601
Force: Disk is not clear, partitions or ZFS labels were found.
So did some further looking and found the "Mirror" of the boot drive as a stripe da0p2, with the flash drive still on the table in front of me.
Now I'm completely confused. How can I, if at all, resolve this without losing 2.5TB of movies and music.
Memory 16311MB
