bitsandnumbers
 - Apr 8, 2013
I just had a power outage and now have some issues with my plugins. I don't think that this is the power outage the problem here though, but more because I had to install a new router (the old one burned) and setup everything in it again. I may have forgotten something in the process...
So here for what I get when I try to start any plugin (the "plugins" service start correctly) :
Jul 17 20:07:38 freenas manage.py: [plugins.utils:71] Couldn't retrieve https://192.168.1.2/plugins/minidlna/_s/status: HTTP Error 502: Bad Gateway
Jul 17 20:07:38 freenas manage.py: [plugins.utils:71] Couldn't retrieve https://192.168.1.2/plugins/transmission/_s/status: HTTP Error 502: Bad Gateway
Jul 17 20:07:38 freenas manage.py: [plugins.utils:71] Couldn't retrieve https://192.168.1.2/plugins/firefly/_s/status: HTTP Error 502: Bad Gateway
Jul 17 20:07:55 freenas INADYN[2770]: INADYN:IP: Error '0x0' resolving host name 'checkip.dyndns.org'
Jul 17 20:07:55 freenas INADYN[2770]: W: DYNDNS: Error 'RC_IP_INVALID_REMOTE_ADDR' (0x12) when talking to IP server
Jul 17 20:07:55 freenas INADYN[2770]: W:'RC_IP_INVALID_REMOTE_ADDR' (0x12) updating the IPs. (it 7)
Jul 17 20:10:17 freenas INADYN[2770]: INADYN:IP: Error '0x0' resolving host name 'checkip.dyndns.org'
Jul 17 20:10:17 freenas INADYN[2770]: W: DYNDNS: Error 'RC_IP_INVALID_REMOTE_ADDR' (0x12) when talking to IP server
Jul 17 20:10:17 freenas INADYN[2770]: W:'RC_IP_INVALID_REMOTE_ADDR' (0x12) updating the IPs. (it 7)
Jul 17 20:12:39 freenas INADYN[2770]: INADYN:IP: Error '0x0' resolving host name 'checkip.dyndns.org'
Jul 17 20:12:39 freenas INADYN[2770]: W: DYNDNS: Error 'RC_IP_INVALID_REMOTE_ADDR' (0x12) when talking to IP server
Jul 17 20:12:39 freenas INADYN[2770]: W:'RC_IP_INVALID_REMOTE_ADDR' (0x12) updating the IPs. (it 7)
Explainations:
> 192.168.1.2 is the ip of the freenas server
> epair0a has ip: 192.168.1.47, whereas epair0b is 192.168.1.51 (I setup the jail to have the latter ip address)
> I'm not sure if the INADYN error is related. My dynamic dns works correctly.
> I use my freenas as a dhcp server, with the help of dnsmasq (setup inside the jail). My server is setup so that dhcp go through freenas first and then router if something goes wrong (so dhcp disabled in router).
> All my local IP addresses are static, so .1.2 is freenas, .1.51 is jail, .1.11 is my computer and so on. All that is setup inside the router itself and dnsmasq.
> The plugins worked correctly before the power outage, with the former router. No changes have been made to freenas since regarding the jail or the plugins. So I assume there's something I forgot inside the router (maybe a NAT rule or sth), but I cannot figure out what...
All help appreciated :)
EDIT: I forgot > although the plugins won't turn on, MiniDLNA works (I can access my medias from my devices through DLNA), also true for Firefly, and Transmission webgui is accessible but cannot access internet (and I assume this is the whole issue here). Strange though that plugins are active even though they're turned off...
Explainations:
