Thanks for responding John!
The new router (Virgin Hub3 - UK version) uses the same ip scheme as my old Virgin Super Hub 2, and I have reserved all the ip addresses used by FreeNAS. UPnP is also enabled.
However, I've been reading some posts regarding the Hub3, which are not great. You can't change the ip ranges, but then I using the standard anyway.
Router IP: 192.168.0.1
Subnet Mask: 255.255.255.0
I can ping 8.8.8.8 within jail and FreeNas, but not
www.google.com from a jail.
[root@freenas ~]# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: icmp_seq=0 ttl=58 time=18.605 ms
64 bytes from 8.8.8.8: icmp_seq=1 ttl=58 time=17.474 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=58 time=20.479 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=58 time=23.287 ms
^C
--- 8.8.8.8 ping statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 17.474/19.961/23.287/2.200 ms
[root@freenas ~]#
[root@freenas ~]# ping www.google.com
PING
www.google.com (62.252.115.157): 56 data bytes
64 bytes from 62.252.115.157: icmp_seq=0 ttl=59 time=21.062 ms
64 bytes from 62.252.115.157: icmp_seq=1 ttl=59 time=17.598 ms
64 bytes from 62.252.115.157: icmp_seq=2 ttl=59 time=20.870 ms
^C
www.google.com ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 17.598/19.843/21.062/1.590 ms
[root@freenas ~]#
root@plexmediaserver_1:/ # ping 8.8.8.8
64 bytes from 8.8.8.8: icmp_seq=0 ttl=58 time=21.393 ms
64 bytes from 8.8.8.8: icmp_seq=1 ttl=58 time=33.019 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=58 time=19.133 ms
^C
round-trip min/avg/max/stddev = 19.133/24.515/33.019/6.084 ms
root@plexmediaserver_1:/ # ping www.google.com
ping: cannot resolve
www.google.com: Host name lookup failure
PLEX ifconfig output:
root@plexmediaserver_1:/ # ifconfig
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
epair4b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:b6:c3:00:0f:0b
        inet 192.168.0.90 netmask 0xffffff00 broadcast 192.168.0.255
        status: active
FreeNAS CLI output:
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 15
00
        options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINK
STATE>
        ether d0:bf:9c:45:fc:b8
        inet 192.168.0.6 netmask 0xffffff00 broadcast 192.168.0.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
bge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=c019b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,VLA
N_HWTSO,LINKSTATE>
        ether d0:bf:9c:45:fc:b9
        media: Ethernet autoselect (none)
        status: no carrier
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
ether 02:eb:ee:cc:a6:00
        nd6 options=1<PERFORMNUD>
        member: epair7a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 12 priority 128 path cost 2000
        member: epair4a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 9 priority 128 path cost 2000
        member: epair8a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 13 priority 128 path cost 2000
        member: epair6a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 11 priority 128 path cost 2000
        member: epair5a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 10 priority 128 path cost 2000
        member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 8 priority 128 path cost 2000
        member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 7 priority 128 path cost 2000
        member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 6 priority 128 path cost 2000
        member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 5 priority 128 path cost 2000
member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu
1500
        options=8<VLAN_MTU>
        ether 02:ff:20:00:05:0a
        status: active
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu
1500
        options=8<VLAN_MTU>
        ether 02:ff:20:00:06:0a
        status: active
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu
1500
        options=8<VLAN_MTU>
        ether 02:ff:20:00:07:0a
        status: active
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu
1500
        options=8<VLAN_MTU>
        ether 02:ff:20:00:08:0a
        status: active
epair5a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu
1500
        options=8<VLAN_MTU>
        ether 02:ff:20:00:0a:0a
        status: active
epair6a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu
1500
        options=8<VLAN_MTU>
        ether 02:ff:20:00:0b:0a
        status: active
epair8a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:ff:20:00:0d:0a
        status: active
epair4a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:ff:20:00:09:0a
        status: active
epair7a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:ff:20:00:0c:0a
        status: active
