marcevan
- Dec 15, 2013
After a failed 9.2.1 upgrade, I reverted to 9.2.0 (fresh) and did not import my config. I built it manually again.
Jail persisted when I imported my pool, so I didn't see that and started downloaded some plugins.
Because of the dual-plugins (same version, same IP) there was some corruption and I wound up removing the dataset jail_2 as there were 2 jails and really, I did not need that.
All plugins are working fine right now, btw.
But my navtree in the GUI cannot show them giving me console errors like (for ex):
I get this in console for each plugin I had newly setup.
I had 5 originally and downloaded 4 before I saw the issues. So the number you see for Couchpotato was the JLS ID for the old version. I verified my current JLS IDs per plugin and it's not matching the errors so I know the errors are referring to the old/deleted jails.
Feb 12 06:00:47 freenas manage.py: [freeadmin.navtree:522] Couldn't retrieve http://(freenasIP)/plugins/couchpotato/1/_s/treemenu: HTTP Error 500: INTERNAL SERVER ERROR
