Plugins GUI on https/SSL shows not working
Harihoudini
Hi Folks..
Noob on Freenas. Installed 9.3 previously (was working well). Upgraded to 9.10. Didn't go well (major jail issues). Then decided on clean install of 9.10 Stable. All worked well until i did the usual update available a couple of days ago. Though update process was smooth, there is a weird quirk with the GUI..I have attached screenshots as well.
Basically the Plugins tree menu on the left side doesn't work and the plugins page also shows all the switches off. In fact they are NOT off, and they are all actually working (so if i try to switch them on again they don't work). If i access the page from http/IP instead of https they all show working correctly.
Something related to WebGUI/SSL/https/permissions maybe?
Both screengrabs attached.
Any ideas?
