Plugins does not show up on the left pane on FreeNAS 11.1-U6
Janus Ng
I have installed 2 plugins on a FreeNAS box, plexmediaserver and nextcloud. Both were running fine. Both are updated time to time up to the latest supported versions manually (unfortunately nextcloud is stuck at version 10.0.06 due to php dependence.)
Unfortunately on Sep 12, the plexmediaserver is missing from the Plugins section on the left pane of the FreeNAS WebUI but the Plugins>Installed tab shows both plugins correctly as shown in the following image: https://imgur.com/a/0WRiARB. However the toggle button on the Service state column does not work. I didn't notice them until Oct 1.
The Jails>Jails tab shows both jails correctly as shown in the picture: https://imgur.com/a/FssyTzQ
The following lines were logged every time the plexmediaserver starts.
Sep 12 17:25:46 freenas uwsgi: [freeadmin.navtree:614] An error occurred while unserializing from https://10.27.0.21/plugins/plexmediaserver/3/_s/treemenu: Expecting value: line 2 column 1 (char 1)
Sep 12 17:28:24 freenas uwsgi: [freeadmin.navtree:614] An error occurred while unserializing from https://10.27.0.21/plugins/plexmediaserver/3/_s/treemenu: Expecting value: line 2 column 1 (char 1)
Sep 12 17:28:30 freenas uwsgi: [freeadmin.navtree:614] An error occurred while unserializing from https://10.27.0.21/plugins/plexmediaserver/3/_s/treemenu: Expecting value: line 2 column 1 (char 1)
Sep 12 17:28:38 freenas uwsgi: [freeadmin.navtree:614] An error occurred while unserializing from https://10.27.0.21/plugins/plexmediaserver/3/_s/treemenu: Expecting value: line 2 column 1 (char 1)
I have uploaded the output of the web link mentioned in the above error. Sorry for zipped it as the forums does not allow uploading html file.
Any advice?
Thanks a ton!
  • ProtocolError at _plugins_plexmediaserver_3__s_treemenu.html.zip
Janus Ng
Unfortunately, no.
I guess I have to reinstall Nextcloud with iocage anyway when FreeNAS 11.2 is released by December.
