syncthing Plugin Won't Start.
ibarton
I have installed the syncthing plugin on FreeNAS 11.1 U5. I have set up two instances, each using their own jail and configured the folders to be owned by syncthing.syncthing. This all worked fine for a couple of days. However, both instances stopped and trying to restart them I get the following error in syslog:
Aug 15 11:49:49 freenas uwsgi: [freeadmin.navtree:614] An error occurred while unserializing from http://192.168.0.10/plugins/syncthing/3/_s/treemenu: Expecting value: line 1 column 1 (char 0)
Aug 15 11:50:19 freenas uwsgi: [plugins.utils:88] Couldn't retrieve http://192.168.0.10/plugins/syncthing/3/_s/status: Expecting value: line 1 column 1 (char 0)
Aug 15 11:53:12 freenas uwsgi: [plugins.utils:88] Couldn't retrieve http://192.168.0.10/plugins/syncthing/3/_s/status: Expecting value: line 1 column 1 (char 0)
Both jails are running OK.
ibarton
Not sure yet. I deleted both instances of the plugin and jails then re-installed a single instance. This appears to be running OK after a few days. I'll try installing another instance of the plugin and see how that goes.
