Plugin script may miss to use absolute path leading to create warden folder into wrong path
iXô
Hello, I am quite new to FreeNAS (and even *BSD), but I think I found a little bug.
First I am describing my configuration :
- Boot system as ZFS with 2 Micro SD Flash drives
- Main ZFS volume as Raid Z2 with 6 T0 drives (named zfstemp)
- Jails root as /mnt/zfstemp/jailsroot
For the moment I've only used the Web GUI.
Because I needed to check permissions for a jail, I went using the console tool from the web gui.
Then here is was I descovered :
- normal volume and everything under it :
[root@freenas /mnt/zfztemp]# ll
total 77
drwxr-xr-x 6 root wheel uarch 6 Jul 26 11:00 ./
drwxr-xr-x 4 root wheel uarch 120 Jul 26 01:06 ../
drwxrwxr-x 3 root wheel uarch 3 Jul 24 21:33 home/
drwxr-xr-x 24 root wheel uarch 24 Jul 26 02:25 jailsroot/
drwxr-xr-x 3 root wheel uarch 3 Jul 26 11:01 temp/
As you can see no problem so far.
But if I do the same thing I folder backward :
[root@freenas /mnt]# ll
total 28
drwxr-xr-x 4 root wheel uarch 120 Jul 26 01:06 ./
drwxr-xr-x 19 root wheel uarch 27 Jul 25 15:14 ../
-rw-r--r-- 1 root wheel uarch 5 Jul 24 20:11 md_size
drwxr-xr-x 3 root wheel - 40 Jul 26 02:16 mnt/
drwxr-xr-x 6 root wheel uarch 6 Jul 26 11:00 zfztemp/
Extra mnt folder here... strange, looking into it :
[root@freenas /mnt/mnt]# ll
total 24
drwxr-xr-x 3 root wheel - 40 Jul 26 02:16 ./
drwxr-xr-x 3 root wheel - 40 Jul 26 11:11 zfztemp/
In fact, the zfstemp here contains a jailsroot folder, and this folder content makes me guess that a script somewhere have a problem. I think the script may be responsible for init a jail because of the content :
[root@freenas /mnt/mnt/zfztemp/jailsroot]# ll
total 82
drwxr-xr-x 4 root wheel - 80 Jul 26 11:11 ./
drwxr-xr-x 3 root wheel - 40 Jul 26 11:11 ../
drwxr-xr-x 8 root wheel uarch 8 Jul 26 11:13 .warden-template-pluginjail--x64-20150726010623/
drwxr-xr-x 9 root wheel uarch 10 Jul 26 11:13 .warden-template-standard--x64/
If I am not wrong, theses datas are not into my zfs volume, but on my boot volume.
What I don't understand is how theses data can be created as the boot volume is mounted read only ?
I wanted to work around this problem by creating a simlink like that : /mnt/mnt -> /mnt
But, so far, I can only go this far :
cd /mnt
mv mnt mnt.temp
ln -s /mnt/ /mnt/mnt
Then I am unable to move datas :
[root@freenas /mnt/mnt]# mv /mnt/mnt.temp/zfztemp/jailsroot/.warden-template-* /mnt/zfztem
p/jailsroot/
mv: rmdir /mnt/zfztemp/jailsroot/.warden-template-pluginjail--x64-20150726010623
: Directory not empty
mv: rmdir /mnt/zfztemp/jailsroot/.warden-template-standard--x64: Directory not e
mpty
Do I have to open a ticket ?
And how can I work around this problem ?
Thanks.
Best regards.
Nucshuco
I am also seeing the /mnt/mnt after installing pluginjail and standard.
X10SRL-F
Processor: Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
32GB ECC DDR4 2133MHz
8x4 WD Reds RAIDZ2
32GB SATA DOM
iXô
After some tests, the warden plugin dataset was for the plugin xdm, and the warden standard dataset was for 2 standard jails.
After deleting jails and plugin, and using zfs destroy -R ... to remove theses folder, using the self symlink trick seems to be a good workaround.
As I am not the only one affected by this strange bug, I will create a bug report.
This problem has plagued me for quite some time. I haven't had a pressing need for a new jail, but I knew I couldn't create new ones because of that bug. Glad to see it is fixed.
