Plugin Mounts - unmounting?
tmacka88
I am having an issue with my plugin mounts. Some of them seam to unmount by themselves and won't auto remount, resulting in me having to log in and click mount again. Are there limitations on how many mounts and using multiple mount points to the same directory or something.
Here are my mounts that seam to always be working:
SABnzbd
Source: /mnt/Volume4/Downloads/Complete
Destination: /usr/pbi/sabnzbdplus-amd64/sabnzbd/Downloads/complete
SickBeard
Source: /mnt/Volume4/jails/sabnzbd_1/usr/pbi/sabnzbdplus-amd64/sabnzbd/Downloads/complete
Destination: /usr/pbi/sickbeard-amd64/data/Downloads
And these are the ones that continue to unmount:
SickBeard
Source: /mnt/Volume4/Media/TV Shows/TV Shows
Destination: /usr/pbi/sickbeard-amd64/data/Media
Thanks
Yatti420
Remove the spaces from the directory paths..
tmacka88
hey mate,
These spaces are required as the folder names have spaces in them. Should I use \ for a space? If so why didnt freenas gui implement this when i selected the folder...
thanks
I think it's time that the folders not have spaces anymore then. :P
Someone else had the problem and afaik the only solution he could find was to get rid of the spaces. Unix doesn't use spaces as liberally as Windows does. Usually its better to use underscores if you want spaces to have full compatiblity with other OSes that are non-Windows.
spaces in nix is a no-no_no.no
mirdragon
I agree remove the spaces - i noticed i was having some trouble with a particular path/share - renamed without spaces and all ok now
tmacka88
yeah this has fixed it. cheers.
