Plexmediaserver service running, but not?
cglavan
I've recently moved to FreeNAS from another platform, so FreeBSD is still relatively new to me. So far I've been very pleased, but now I've hit a snag.
I installed the Plex plugin using NAT (the VLAN my NAS resides in does not have a DHCP scope) and the install completes successfully, however I'm unable to access the web UI either in Firefox or Chrome. I thought this was odd since I installed the NextCloud plugin the same way and I can access it without issue. I went digging in the jail and here's what I found:
root@GlavaPlex:~ # service plexmediaserver status
plexmediaserver is not running.
root@GlavaPlex:~ # service plexmediaserver start
Starting plexmediaserver.
daemon: process already running, pid: 7271
/usr/local/etc/rc.d/plexmediaserver: WARNING: failed to start plexmediaserver
How can plex not be running but also have a pid and the system unable to start it?
root@GlavaPlex:~ # sockstat | grep plex
plex Plex Tuner 7278 13 tcp4 127.0.0.1:32600 *:*
plex Plex Tuner 7278 63 tcp4 127.0.0.1:50605 127.0.0.1:17186
plex Plex Tuner 7278 64 tcp4 127.0.0.1:17186 127.0.0.1:50605
plex Plex Tuner 7278 65 tcp4 127.0.0.1:36196 127.0.0.1:25185
plex Plex Tuner 7278 66 tcp4 127.0.0.1:25185 127.0.0.1:36196
plex Plex Tuner 7278 68 tcp4 127.0.0.1:37204 127.0.0.1:51828
plex Plex Tuner 7278 69 tcp4 127.0.0.1:60211 127.0.0.1:56248
plex Plex Tuner 7278 71 tcp4 127.0.0.1:56248 127.0.0.1:60211
plex Plex Scrip 7273 10 tcp4 127.0.0.1:51828 *:*
plex Plex Media 7272 60 tcp46 *:32400 *:*
plex Plex Media 7272 61 tcp4 127.0.0.1:32401 *:*
plex Plex Media 7272 76 udp4 *:32414 *:*
plex Plex Media 7272 77 udp4 *:32412 *:*
plex Plex Media 7272 78 udp4 *:32410 *:*
plex Plex Media 7272 80 udp4 *:32413 *:*
plex Plex Media 7272 83 udp4 172.16.0.6:64873 *:*
plex Plex Media 7272 84 udp4 172.16.0.6:26376 *:*
plex Plex Media 7272 86 udp4 *:1901 *:*
plex Plex Media 7272 87 udp4 172.16.0.6:33500 *:*
root@GlavaPlex:~ # ps auxw | grep -i plex
plex 7271 0.0 0.0 6384 2024 - IsJ 23:57 0:00.00 daemon: /usr/local/share/plexmediaserver/Plex_Media_Server[7272] (daemon)
plex 7272 0.0 1.6 135120 67220 - IJ 23:57 0:07.77 /usr/local/share/plexmediaserver/Plex_Media_Server (Plex Media Server)
plex 7273 0.0 1.4 93872 57356 - INJ 23:57 0:07.25 Plex Plug-in [com.plexapp.system] /usr/local/share/plexmediaserver/Resour
plex 7278 0.0 0.5 32036 20856 - IJ 23:57 0:00.17 /usr/local/share/plexmediaserver/Plex Tuner Service /usr/local/share/plex
root 9807 0.0 0.1 6732 2544 1 S+J 01:05 0:00.00 grep -i plex
root@GlavaPlex:~ # ifconfig -a
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:24:1d:06:51:13
hwaddr 02:d4:bd:00:05:0b
inet 172.16.0.6 netmask 0xfffffffc broadcast 172.16.0.7
nd6 options=1<PERFORMNUD>
status: active
groups: epair
root@GN-NAS[~]# ifconfig -a
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: re0
options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
ether 00:24:1d:53:1c:46
hwaddr 00:24:1d:53:1c:46
inet 192.168.20.100 netmask 0xffffff00 broadcast 192.168.20.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
vnet0.1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: GlavArchive as nic: epair0b
options=8<VLAN_MTU>
ether 02:24:1d:6a:fc:5e
hwaddr 02:e2:d0:00:03:0a
inet 172.16.0.1 netmask 0xfffffffc broadcast 172.16.0.3
status: active
groups: epair
vnet0.2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: GlavaPlex as nic: epair0b
options=8<VLAN_MTU>
ether 02:24:1d:06:51:12
hwaddr 02:e2:d0:00:04:0a
inet 172.16.0.5 netmask 0xfffffffc broadcast 172.16.0.7
status: active
groups: epair
root@GlavaPlex:/Plex Media Server # cat Preferences.xml
<?xml version="1.0" encoding="utf-8"?>
<Preferences OldestPreviousVersion="1.20.1.3252-a78fef9a9" MachineIdentifier="ba3ed4bd-e6be-42b6-9c7f-dea6035764dd" ProcessedMachineIdentifier="17409e50e02085f8cb872b80c139c3fde1e024f0" AnonymousMachineIdentifier="77142a9e-4a37-41af-861b-4cda04f28f91" MetricsEpoch="1"/>
I'm much less familiar with BSD than I am with Debian, so if anyone could point me in the right direction I would greatly appreciate it-- it is the end of the world after all, and I want to watch movies!
Thank you!
cglavan
Here's logs if it helps (too many characters for an inline post).
  • PlexMediaServer_Logs.txt
  • com_plexapp_system_Logs.txt
cglavan
Cannot edit my own posts yet, apologies.
FreeNAS 11.3-U4.1
Plex version 1.20.1.3252, release 11.3-RELEASE-p13
Bikerchris
Have you tried manually typing https before the IP? I fumbled the other day with my install by clicking "connect securely only".
The status may be wrong due to a permission issue on /var/run/plex/plex.pid (if the file is even there) in the jail.
To fix that create the file and give ownership to the user that runs plex.
Then when you start the service, the pid of the running process should be put in that file and status will be able to see that it's running.
Separate to that you need to work out if connecting to http://jail.ip.address:32400 is working.
