no1jam
- Feb 22, 2021
Hello, as the title says, I have a single Plex jail.
I have two VLAN's (1, and 86) that are isolated via firewall rules.
My goal, if possible, if for Plex to serve to the LAN on VLAN 1, and serve to the WAN on VLAN 86, and for the traffic in my network to stay isolated.
I'm curious to know if anyone else has done this before. I have read / watched some threads and tutorials but haven't been able to get the config just right yet.
Here's what I have so far:
ifconfig -
IO Cage get all -
ifconfig -
root@truenas[~]# ifconfig igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: igb0 options=a520b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6> ether 5c:f3:fc:b3:24:09 inet 192.168.1.10 netmask 0xffffff00 broadcast 192.168.1.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active nd6 options=9<PERFORMNUD,IFDISABLED> bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: 86 vlan options=8009b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,LINKSTATE> ether 00:10:18:0f:ae:f8 inet 10.0.86.10 netmask 0xffffff00 broadcast 10.0.86.255 media: Ethernet autoselect (none) status: no carrier nd6 options=9<PERFORMNUD,IFDISABLED> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> pflog0: flags=0<> metric 0 mtu 33160 groups: pflog ue0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 5e:f3:fc:b3:24:10 nd6 options=1<PERFORMNUD> bridge86: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: bge0 bridge for 86 vlan ether 02:6c:ef:f2:80:56 id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto stp-rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 2 priority 128 path cost 55 groups: bridge nd6 options=9<PERFORMNUD,IFDISABLED> bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:6c:ef:f2:80:00 id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto stp-rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: vnet0.4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 8 priority 128 path cost 2000 member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 groups: bridge nd6 options=1<PERFORMNUD> vnet0.4: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: plex as nic: epair0b options=8<VLAN_MTU> ether 5e:f3:fc:14:fa:09 hwaddr 02:53:6f:d4:41:0a groups: epair media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active nd6 options=1<PERFORMNUD>
IO Cage get all -
root@truenas[~]# iocage get all plex CONFIG_VERSION:28 allow_chflags:0 allow_mlock:0 allow_mount:0 allow_mount_devfs:0 allow_mount_fusefs:0 allow_mount_nullfs:0 allow_mount_procfs:0 allow_mount_tmpfs:0 allow_mount_zfs:0 allow_quotas:0 allow_raw_sockets:0 allow_set_hostname:1 allow_socket_af:0 allow_sysvipc:0 allow_tun:0 allow_vmm:0 assign_localhost:0 available:readonly basejail:1 boot:1 bpf:1 children_max:0 comment:none compression:lz4 compressratio:readonly coredumpsize:off count:1 cpuset:off cputime:off datasize:off dedup:off defaultrouter:auto defaultrouter6:auto depends:none devfs_ruleset:4 dhcp:1 enforce_statfs:2 exec_clean:1 exec_created:/usr/bin/true exec_fib:0 exec_jail_user:root exec_poststart:/usr/bin/true exec_poststop:/usr/bin/true exec_prestart:/usr/bin/true exec_prestop:/usr/bin/true exec_start:/bin/sh /etc/rc exec_stop:/bin/sh /etc/rc.shutdown exec_system_jail_user:0 exec_system_user:root exec_timeout:60 host_domainname:none host_hostname:plex host_hostuuid:plex host_time:1 hostid:b32dbc38-603e-11e4-ab8c-5cf3fcb32409 hostid_strict_check:0 interfaces:vnet0:bridge0 ip4:new ip4_addr:192.168.1.12/24,10.0.86.12/24 ip4_saddrsel:1 ip6:new ip6_addr:none ip6_saddrsel:1 ip_hostname:0 jail_zfs:0 jail_zfs_dataset:iocage/jails/plex/data jail_zfs_mountpoint:none last_started:2022-05-19 15:24:44 localhost_ip:none login_flags:-f root mac_prefix:5ef3fc maxproc:off memorylocked:off memoryuse:off min_dyn_devfs_ruleset:1000 mount_devfs:1 mount_fdescfs:1 mount_linprocfs:0 mount_procfs:0 mountpoint:readonly msgqqueued:off msgqsize:off nat:0 nat_backend:ipfw nat_forwards:none nat_interface:none nat_prefix:172.16 nmsgq:off notes:none nsem:off nsemop:off nshm:off nthr:off openfiles:off origin:readonly owner:root pcpu:off plugin_name:plexmediaserver plugin_repository:https://github.com/freenas/iocage-ix-plugins.git priority:99 pseudoterminals:off quota:none readbps:off readiops:off release:12.1-RELEASE-p13 reservation:none resolver:/etc/resolv.conf rlimits:off rtsold:0 securelevel:2 shmsize:off stacksize:off state:up stop_timeout:30 swapuse:off sync_state:none sync_target:none sync_tgt_zpool:none sysvmsg:new sysvsem:new sysvshm:new template:0 type:pluginv2 used:readonly vmemoryuse:off vnet:1 vnet0_mac:5ef3fc14fa09 5ef3fc14fa0a vnet0_mtu:auto vnet1_mac:none vnet1_mtu:auto vnet2_mac:none vnet2_mtu:auto vnet3_mac:none vnet3_mtu:auto vnet_default_interface:auto vnet_default_mtu:1500 vnet_interfaces:none wallclock:off writebps:off writeiops:off
