I've got a new setup that refuses to use hardware transcoding.  While my linux knowledge is very little, i work in IT so i'm not entirely useless.  Details are below, please ask if there's anything important i'm missing.
First off, i'm on TrueNAS-SCALE-23.10.2 with the CPU being an N3450. GPU use is enabled on the container (i selected the option for 1, even though it goes up to 5, since i only have the one. I assume this is correct?) and is listed as gpu.intel.com/i915 GPU.
it's also set in plex to use this rather than leaving it on Auto.
among the things i have read is this thread, and while its a different CPU, theirs is Jasper Lake v my Apollo Lake, it's the same GPU, so i assume would be the same, or similar, process.
the below says its booting with enable_guc=2 rather than 3 advised in that thread, but it didn't work with 3. I can reset it to get the exact error if needed but i'm pretty sure it was complaining about guc submission being disabled.
guc info shows -
huc info shows -
Since i think that was different before, lets reset it to guc=3 and see what it says.
Though this isn't really running with guc=3 as the below shows.
firmware list is shown below.
I'm hoping someone can point out what is going on here, and how i can resolve it.
Thanks
admin@truenas[~]$ sudo dmesg | grep i915 [sudo] password for admin: [ 0.000000] Command line: BOOT_IMAGE=/ROOT/23.10.2@/boot/vmlinuz-6.1.74-production+truenas root=ZFS=boot-pool/ROOT/23.10.2 ro libata.allow_tpm=1 amd_iommu=on iommu=pt kvm_amd.npt=1 kvm_amd.avic=1 intel_iommu=on zfsforce=1 nvme_core.multipath=N i915.enable_guc=2 [ 0.049072] Kernel command line: BOOT_IMAGE=/ROOT/23.10.2@/boot/vmlinuz-6.1.74-production+truenas root=ZFS=boot-pool/ROOT/23.10.2 ro libata.allow_tpm=1 amd_iommu=on iommu=pt kvm_amd.npt=1 kvm_amd.avic=1 intel_iommu=on zfsforce=1 nvme_core.multipath=N i915.enable_guc=2 [ 11.806137] i915 0000:00:02.0: vgaarb: deactivate vga console [ 11.806624] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem [ 11.811091] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/bxt_dmc_ver1_07.bin (v1.7) [ 12.080812] i915 0000:00:02.0: [drm] failed to retrieve link info, disabling eDP [ 12.097746] i915 0000:00:02.0: [drm] GuC firmware i915/bxt_guc_70.1.1.bin version 70.1.1 [ 12.097770] i915 0000:00:02.0: [drm] HuC firmware i915/bxt_huc_2.0.0.bin version 2.0.0 [ 12.113897] i915 0000:00:02.0: [drm] HuC authenticated [ 12.113918] i915 0000:00:02.0: [drm] GuC submission disabled [ 12.113923] i915 0000:00:02.0: [drm] GuC SLPC disabled [ 12.116653] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0 [ 12.119058] snd_hda_intel 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915]) [ 12.121153] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes [ 12.122944] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes [ 12.124461] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
guc info shows -
admin@truenas[~]$ sudo cat /sys/kernel/debug/dri/0/gt/uc/guc_info
GuC firmware: i915/bxt_guc_70.1.1.bin
        status: RUNNING
        version: found 70.1.1
        uCode: 206080 bytes
        RSA: 256 bytes
GuC status 0x8003f0ed:
        Bootrom status = 0x76
        uKernel status = 0xf0
        MIA Core status = 0x3
Scratch registers:
         0:     0xf0000000
         1:     0x1
         2:     0x1000
         3:     0x0
         4:     0x40
         5:     0x3ca
         6:     0x5a85000b
         7:     0x0
         8:     0x0
         9:     0x0
        10:     0x0
        11:     0x0
        12:     0x0
        13:     0x0
        14:     0x0
        15:     0x0
GuC logging stats:
        Relay full count: 0
        DEBUG:  flush count          0, overflow count          0
        CRASH:  flush count          0, overflow count          0
        CAPTURE:        flush count          0, overflow count          0huc info shows -
admin@truenas[~]$ admin@truenas[~]$ sudo cat /sys/kernel/debug/dri/0/gt/uc/huc_info zsh: no matches found: admin@truenas[~]$
HuC firmware: i915/bxt_huc_2.0.0.bin
        status: RUNNING
        version: found 2.0.0
        uCode: 149440 bytes
        RSA: 256 bytes
HuC status: 0x00006080Though this isn't really running with guc=3 as the below shows.
admin@truenas[~]$ sudo dmesg | grep i915 [ 0.000000] Command line: BOOT_IMAGE=/ROOT/23.10.2@/boot/vmlinuz-6.1.74-production+truenas root=ZFS=boot-pool/ROOT/23.10.2 ro libata.allow_tpm=1 amd_iommu=on iommu=pt kvm_amd.npt=1 kvm_amd.avic=1 intel_iommu=on zfsforce=1 nvme_core.multipath=N i915.enable_guc=3 [ 0.049960] Kernel command line: BOOT_IMAGE=/ROOT/23.10.2@/boot/vmlinuz-6.1.74-production+truenas root=ZFS=boot-pool/ROOT/23.10.2 ro libata.allow_tpm=1 amd_iommu=on iommu=pt kvm_amd.npt=1 kvm_amd.avic=1 intel_iommu=on zfsforce=1 nvme_core.multipath=N i915.enable_guc=3 [ 11.810276] i915 0000:00:02.0: [drm] Incompatible option enable_guc=3 - GuC submission is N/A [ 11.814601] i915 0000:00:02.0: vgaarb: deactivate vga console [ 11.821743] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem [ 11.825371] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/bxt_dmc_ver1_07.bin (v1.7) [ 12.100477] i915 0000:00:02.0: [drm] failed to retrieve link info, disabling eDP [ 12.135388] i915 0000:00:02.0: [drm] GuC firmware i915/bxt_guc_70.1.1.bin version 70.1.1 [ 12.135414] i915 0000:00:02.0: [drm] HuC firmware i915/bxt_huc_2.0.0.bin version 2.0.0 [ 12.151264] i915 0000:00:02.0: [drm] HuC authenticated [ 12.151286] i915 0000:00:02.0: [drm] GuC submission disabled [ 12.151292] i915 0000:00:02.0: [drm] GuC SLPC disabled [ 12.154534] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0 [ 12.157981] snd_hda_intel 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915]) [ 12.160128] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes [ 12.161740] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes [ 12.163222] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
admin@truenas[~]$ ls /lib/firmware/i915 adlp_dmc.bin bxt_dmc_ver1_07.bin cml_guc_33.0.0.bin dg1_guc_70.bin ehl_guc_62.0.0.bin glk_huc_ver03_01_2893.bin kbl_dmc_ver1_01.bin mtl_dmc.bin skl_guc_70.1.1.bin tgl_guc_35.2.0.bin adlp_dmc_ver2_09.bin bxt_guc_32.0.3.bin cml_guc_49.0.1.bin dg1_huc.bin ehl_guc_69.0.3.bin icl_dmc_ver1_07.bin kbl_dmc_ver1_04.bin rkl_dmc_ver2_02.bin skl_guc_ver1.bin tgl_guc_49.0.1.bin adlp_dmc_ver2_10.bin bxt_guc_33.0.0.bin cml_guc_62.0.0.bin dg1_huc_7.7.1.bin ehl_guc_70.1.1.bin icl_dmc_ver1_09.bin kbl_guc_32.0.3.bin rkl_dmc_ver2_03.bin skl_guc_ver4.bin tgl_guc_62.0.0.bin adlp_dmc_ver2_12.bin bxt_guc_49.0.1.bin cml_guc_69.0.3.bin dg1_huc_7.9.3.bin ehl_huc_9.0.0.bin icl_guc_32.0.3.bin kbl_guc_33.0.0.bin skl_dmc_ver1.bin skl_guc_ver6.bin tgl_guc_69.0.3.bin adlp_dmc_ver2_14.bin bxt_guc_62.0.0.bin cml_guc_70.1.1.bin dg2_dmc_ver2_06.bin glk_dmc_ver1_04.bin icl_guc_33.0.0.bin kbl_guc_49.0.1.bin skl_dmc_ver1_23.bin skl_guc_ver6_1.bin tgl_guc_70.1.1.bin adlp_dmc_ver2_16.bin bxt_guc_69.0.3.bin cml_huc_4.0.0.bin dg2_dmc_ver2_07.bin glk_guc_32.0.3.bin icl_guc_49.0.1.bin kbl_guc_62.0.0.bin skl_dmc_ver1_26.bin skl_guc_ver9_33.bin tgl_guc_70.bin adlp_guc_62.0.3.bin bxt_guc_70.1.1.bin cnl_dmc_ver1_07.bin dg2_dmc_ver2_08.bin glk_guc_33.0.0.bin icl_guc_62.0.0.bin kbl_guc_69.0.3.bin skl_dmc_ver1_27.bin skl_huc_2.0.0.bin tgl_huc.bin adlp_guc_69.0.3.bin bxt_guc_ver8_7.bin dg1_dmc_ver2_02.bin dg2_guc_70.1.2.bin glk_guc_49.0.1.bin icl_guc_69.0.3.bin kbl_guc_70.1.1.bin skl_guc_32.0.3.bin skl_huc_ver01_07_1398.bin tgl_huc_7.0.12.bin adlp_guc_70.1.1.bin bxt_guc_ver9_29.bin dg1_guc_49.0.1.bin dg2_guc_70.4.1.bin glk_guc_62.0.0.bin icl_guc_70.1.1.bin kbl_guc_ver9_14.bin skl_guc_33.0.0.bin tgl_dmc_ver2_04.bin tgl_huc_7.0.3.bin adlp_guc_70.bin bxt_huc_2.0.0.bin dg1_guc_62.0.0.bin dg2_guc_70.bin glk_guc_69.0.3.bin icl_huc_9.0.0.bin kbl_guc_ver9_39.bin skl_guc_49.0.1.bin tgl_dmc_ver2_06.bin tgl_huc_7.5.0.bin adls_dmc_ver2_01.bin bxt_huc_ver01_07_1398.bin dg1_guc_69.0.3.bin ehl_guc_33.0.4.bin glk_guc_70.1.1.bin icl_huc_ver8_4_3238.bin kbl_huc_4.0.0.bin skl_guc_62.0.0.bin tgl_dmc_ver2_08.bin tgl_huc_7.9.3.bin bxt_dmc_ver1.bin bxt_huc_ver01_8_2893.bin dg1_guc_70.1.1.bin ehl_guc_49.0.1.bin glk_huc_4.0.0.bin kbl_dmc_ver1.bin kbl_huc_ver02_00_1810.bin skl_guc_69.0.3.bin tgl_dmc_ver2_12.bin
Thanks
