Please give me some hints
skulkrik
Hello
I recently had an issue with my file server, the power supply broke. When I replaced and rebooted FreeNAS the auto import failed on the last step (3/3) with the comment "You already have a volume with same name" but I cannot see any volumes. I've been looking around in the forum but have not found anything on this problem. I could really use some help so I do not break anything while investigating this failure. What are the first steps I should do to find out if it is a broken disk?
I'm running an old version of FreeNAS on the machine FreeNAS-9.2.1.8-RELEASE-x64.
Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
		The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.2-RELEASE-p12 #0 r262572+b043649: Sun Sep 28 23:03:31 PDT 2014
	root@build3.ixsystems.com:/tank/home/jkh/build/921/freenas/os-base/amd64/fusion/jkh/921/freenas/FreeBSD/src/sys/FREENAS.amd64 am
d64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Core(TM) i5-3470T CPU @ 2.90GHz (2900.08-MHz K8-class CPU)
  Origin = "GenuineIntel"  Id = 0x306a9  Family = 0x6  Model = 0x3a  Stepping = 9
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,
HTT,TM,PBE>
  Features2=0x7fbae3ff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT
,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
  AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
  AMD Features2=0x1<LAHF>
  Standard Extended Features=0x281<GSFSBASE,SMEP,ENHMOVSB>
  TSC: P-state invariant, performance statistics
real memory  = 17179869184 (16384 MB)
avail memory = 16210456576 (15459 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <ALASKA A M I>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 SMT threads
 cpu0 (BSP): APIC ID:  0
 cpu1 (AP): APIC ID:  1
 cpu2 (AP): APIC ID:  2
 cpu3 (AP): APIC ID:  3
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110527/tbfadt-320)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <ALASKA A M I> on motherboard
ACPI Error: [RAMB] Namespace lookup failure, AE_NOT_FOUND (20110527/psargs-392)
ACPI Exception: AE_NOT_FOUND, Could not execute arguments for [RAMW] (Region) (20110527/nsinit-380)
acpi0: Power Button (fixed)
acpi0: reservation of 67, 1 (4) failed
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
Event timer "HPET1" frequency 14318180 Hz quality 440
Event timer "HPET2" frequency 14318180 Hz quality 440
Event timer "HPET3" frequency 14318180 Hz quality 440
Event timer "HPET4" frequency 14318180 Hz quality 440
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xf7800000-0xf7bfffff,0xe0000000-0xefffffff irq 16 at device 2.0 on pci0
agp0: <IvyBridge desktop GT1 IG> on vgapci0
agp0: aperture size is 256M, detected 262140k stolen memory
pci0: <serial bus, USB> at device 20.0 (no driver attached)
pci0: <simple comms> at device 22.0 (no driver attached)
ehci0: <Intel Panther Point USB 2.0 controller> mem 0xf7c17000-0xf7c173ff irq 23 at device 26.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
pci0: <multimedia, HDA> at device 27.0 (no driver attached)
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
pci3: <ACPI PCI bus> on pcib3
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xe000-0xe0ff mem 0xf0004000-0xf0004fff,0xf0000000-0xf0003fff
irq 16 at device 0.0 on pci3
re0: Using 1 MSI-X message
re0: Chip rev. 0x48000000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
rgephy0:  none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT-FDX, 1000baseT-FDX-m
aster, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: 60:a4:4c:42:91:d7
ehci1: <Intel Panther Point USB 2.0 controller> mem 0xf7c16000-0xf7c163ff irq 23 at device 29.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci1
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel Panther Point SATA300 controller> port 0xf110-0xf117,0xf100-0xf103,0xf0f0-0xf0f7,0xf0e0-0xf0e3,0xf0d0-0xf0df,0xf0c0-
0xf0cf irq 19 at device 31.2 on pci0
ata2: <ATA channel> at channel 0 on atapci0
ata3: <ATA channel> at channel 1 on atapci0
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
atapci1: <Intel Panther Point SATA300 controller> port 0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf090-0xf097,0xf080-0xf083,0xf070-0xf07f,0xf060-
0xf06f irq 19 at device 31.5 on pci0
ata4: <ATA channel> at channel 0 on atapci1
ata5: <ATA channel> at channel 1 on atapci1
acpi_button0: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
ichwd0 on isa0
orm0: <ISA Option ROM> at iomem 0xc0000-0xce7ff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe00052b8c40 with IPv6 initialized (100409)
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
usbus0: 480Mbps High Speed USB v2.0
usbus1: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
ada0 at ata2 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada0: Serial Number WD-WCC1T0637555
ada0: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad4
ada1 at ata3 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada1: Serial Number WD-WCC1T0565357
ada1: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad6
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #2 Launched!
Timecounter "TSC-low" frequency 1450040826 Hz quality 1000
ugen0.2: <vendor 0x8087> at usbus0
uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
Root mount waiting for: usbus1 usbus0
uhub2: 6 ports with 6 removable, self powered
uhub3: 8 ports with 8 removable, self powered
Root mount waiting for: usbus0
ugen0.3: <SanDisk> at usbus0
umass0: <SanDisk Cruzer Fit, class 0/0, rev 2.00/1.26, addr 3> on usbus0
umass0:  SCSI over Bulk-Only; quirks = 0x4100
umass0:5:0:-1: Attached to scbus5
Trying to mount root from ufs:/dev/ufs/FreeNASs2a [ro]...
mountroot: waiting for device /dev/ufs/FreeNASs2a ...
da0 at umass-sim0 bus 0 scbus5 target 0 lun 0
da0: <SanDisk Cruzer Fit 1.26> Removable Direct Access SCSI-5 device
da0: Serial Number 4C532000040919112521
da0: 40.000MB/s transfers
da0: 7633MB (15633408 512 byte sectors: 255H 63S/T 973C)
da0: quirks=0x2<NO_6_BYTE>
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI:	 Crypto: hardware
vboxdrv: fAsync=0 offMin=0x1d6 offMax=0xc98
GEOM_ELI: Device gptid/50d67e08-d82b-11e2-b383-60a44c4291d7.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI: Device gptid/5134ec94-d82b-11e2-b383-60a44c4291d7.eli created.
GEOM_ELI: Device gptid/50d67e08-d82b-11e2-b383-60a44c4291d7.eli destroyed.
GEOM_ELI: Device gptid/5134ec94-d82b-11e2-b383-60a44c4291d7.eli destroyed.
kdragon75
What's the output of zpool list -v & zpool import?
Chris Moore
Is this encrypted?
skulkrik
Hi and thank you very much assisting me. I'm a bit surprised/worried because I got two different results when I ran the commands yesterday evening and now today.
The setup is encrypted and I have both key file and recovery key file stored in a safe location.
From yesterday:
[root@freenas] ~# zpool list -v
no pools available
[root@freenas ~]# zpool import
   pool: main
  state: DEGRADED
 status: One or more devices are missing from the system.
 action: The pool can be imported despite missing or damaged devices.  The
		fault tolerance of the pool may be compromised if imported.
   see: http://illumos.org/msg/ZFS-8000-2Q
		main												DEGRADED
		  mirror-0										  DEGRADED
			gptid/50d67e08-d82b-11e2-b383-60a44c4291d7.eli  ONLINE
			7388996361656512790							 UNAVAIL  cannot open
From today:
no pools available
[root@freenas] ~# zpool import
   pool: main
  state: ONLINE
 status: The pool is formatted using a legacy on-disk version.
 action: The pool can be imported using its name or numeric identifier, though
		some features will not be available without an explicit 'zpool upgrade'.
		main												ONLINE
		  mirror-0										  ONLINE
			gptid/5134ec94-d82b-11e2-b383-60a44c4291d7.eli  ONLINE
skulkrik
I still get the same response (today and yesterday) when trying to do auto-import with the gui, everything works until the last step when I select the volume and it fails with "You already have a volume with same name".
Clearly there are a few things happening here:
The pool was already imported behind the GUI's back. zpool export main it in the CLI and try again. Either that or you have another pool called main already imported ( zpool status is your friend.
As for the different outcomes, either the disk took longer to open (baaaaaad sign) or it was unplugged (poor connection, reseat the cables) or it was failing but managed to recover just enough for FreeNAS/ZFS to start figuring things out.
In any case, you have a mirror, so not too much to worry about.
skulkrik
I've kept investigating the forum and my symptoms. I first thought it might be an issue with the amount of memory but I have 16GB so it should be enough.
If I do not first try to auto-import the volume i cannot see anything using the terminal
no pools available
[root@freenas] ~#
After trying to auto-import the volume using the gui I get the same error as before. Then I tried again using CLI and got the following
no pools available
   pool: main
  state: ONLINE
		main												ONLINE
		  mirror-0										  ONLINE
[root@freenas] ~# zpool status
no pools available
[root@freenas] ~# zpool export main
cannot open 'main': no such pool
[root@freenas] ~# zpool import main
cannot mount '/main': failed to create mountpoint
cannot mount '/main/.system': failed to create mountpoint
cannot mount '/main/.system/cores': failed to create mountpoint
cannot mount '/main/.system/rrd-a0448bd3cb9f4746a91c6f36b7d1bc44': failed to create mountpoint
cannot mount '/main/.system/samba4': failed to create mountpoint
cannot mount '/main/.system/syslog-a0448bd3cb9f4746a91c6f36b7d1bc44': failed to create mountpoint
cannot mount '/main/Media': failed to create mountpoint
cannot mount '/main/PluginsJail': failed to create mountpoint
cannot mount '/main/jails': failed to create mountpoint
cannot mount '/main/jails/.warden-template-pluginjail': failed to create mountpoint
cannot mount '/main/jails/plexmediaserver_1': failed to create mountpoint
cannot mount '/main/jails/plexmediaserver_2': failed to create mountpoint
  pool: main
 state: ONLINE
status: The pool is formatted using a legacy on-disk format.  The pool can
		still be used, but some features are unavailable.
action: Upgrade the pool using 'zpool upgrade'.  Once this is done, the
		pool will no longer be accessible on software that does not support feature
		flags.
  scan: scrub repaired 0 in 8h32m with 0 errors on Sun Aug 12 08:32:41 2018
		NAME												STATE	 READ WRITE CKSUM
		main												ONLINE	   0	 0	 0
		  mirror-0										  ONLINE	   0	 0	 0
			gptid/50d67e08-d82b-11e2-b383-60a44c4291d7.eli  ONLINE	   0	 0	 0
			gptid/5134ec94-d82b-11e2-b383-60a44c4291d7.eli  ONLINE	   0	 0	 0
errors: No known data errors
[root@freenas] ~#
Chris Moore
Show us the output of zfs list please.
The thing that looks like is happening is that the pool is being imported but it is not able to be mounted.
skulkrik
Changing the import command to deal with mnt point it seem to work but the jails are not working. Will continue working on that tomorrow.
But the volume is not visible in the GUI.
First tried without mounting it in the GUI. Did not work.
[root@freenas] ~# zpool status -v
no pools available
[root@freenas] ~# zpool import -f -R /mnt main
cannot import 'main': no such pool available
no pools available
Second time, tried it after failing to mount using GUI.
  pool: main
 state: ONLINE
		flags.
		main												ONLINE	   0	 0	 0
NAME   SIZE  ALLOC   FREE	CAP  DEDUP  HEALTH  ALTROOT
main  2.72T  2.47T   250G	91%  1.00x  ONLINE  /mnt
[root@freenas] ~# zfs list
NAME												   USED  AVAIL  REFER  MOUNTPOINT
main												  2.47T   207G  2.47T  /mnt/main
main/.system										  11.8M   207G   176K  /mnt/main/.system
main/.system/cores									 144K   207G   144K  /mnt/main/.system/cores
main/.system/rrd-a0448bd3cb9f4746a91c6f36b7d1bc44	  144K   207G   144K  /mnt/main/.system/rrd-a0448bd3cb9f4746a91c6f36b7d1bc44
main/.system/samba4								   3.91M   207G  3.91M  /mnt/main/.system/samba4
main/.system/syslog-a0448bd3cb9f4746a91c6f36b7d1bc44  7.44M   207G  7.44M  /mnt/main/.system/syslog-a0448bd3cb9f4746a91c6f36b7d1bc							  44
main/Media											92.5M   207G  92.5M  /mnt/main/Media
main/PluginsJail									   498M   207G   498M  /mnt/main/PluginsJail
main/jails											9.06G   207G   336K  /mnt/main/jails
main/jails/.warden-template-pluginjail				1.24G   207G  1.23G  /mnt/main/jails/.warden-template-pluginjail
main/jails/plexmediaserver_1						  3.29G   207G  4.52G  /mnt/main/jails/plexmediaserver_1
main/jails/plexmediaserver_2						  4.52G   207G  5.75G  /mnt/main/jails/plexmediaserver_2
[root@freenas] ~#
main/.system/syslog-a0448bd3cb9f4746a91c6f36b7d1bc44  7.44M   207G  7.44M  /mnt/main/.system/syslog-a0448bd3cb9f4746a91c6f36b7d1bc44
[root@freenas] ~#
Restarting the CIFS manually allow me to access the drives from a windows machine so the data i still there but there seems to be something wrong. I cannot access any of the jails and the GUI cannot find the volumes nor do auto-mount when I restart the FreeNAS machine. Maybe the USB stick with the FreeNAS SW on it has become corrupt? I'll look for another USB stick and try to boot the computer with a new installation of FreeNAS on it.
Chris Moore
You are not doing it properly AND you are not responding to any of the input you are being given.
skulkrik
I'm very sorry Chris, I was trying to understand the command and I tried to import it with a mountpoint as well.
This command was described in the following thread that I at first believed was similar to my issue:
https://forums.freenas.org/index.php?threads/zpool-import-not-able-to-mount.42123/
I'm very grateful for your assistance and I believed that I have responded to inputs and help you and the others
have provided. When I respond to your input I also try to include the context of the commands that I tried so you
can see the sequences and not only the actual response.
I was very tired yesterday (it was way after midnight here and I had worked a very long day) and I may have misunderstood
things then. Sorry about that :(
I'm also guessing that we are in very different time zones and that may make my answers seems to take a long time but
I need to sleep or take care of my children at some time :)
Chris Moore said:
Is this encrypted?
Yes, it is encrypted. Could that be the reason why I cannot see the volume at all until I try to auto import the volume using the GUI?
I tried to import the pool again to run "zfs list", I hope I did it correctly but I'm not sure if I need to be explicit so I
tried both "zpool import" and "zpool import main" the results was quite different. What should the mount command be to do it correctly?
no pools available
no pools available
   pool: main
  state: ONLINE
		main												ONLINE
		  mirror-0										  ONLINE
no datasets available
main												  2.47T   207G  2.47T  /main
main/.system										  11.8M   207G   176K  /main/.system
main/.system/cores									 144K   207G   144K  /main/.system/cores
main/.system/rrd-a0448bd3cb9f4746a91c6f36b7d1bc44	  144K   207G   144K  /main/.system/rrd-a0448bd3cb9f4746a91c6f36b7d1bc44
main/.system/samba4								   3.91M   207G  3.91M  /main/.system/samba4
main/.system/syslog-a0448bd3cb9f4746a91c6f36b7d1bc44  7.44M   207G  7.44M  /main/.system/syslog-a0448bd3cb9f4746a91c6f36b7d1bc44
main/Media											92.5M   207G  92.5M  /main/Media
main/PluginsJail									   498M   207G   498M  /main/PluginsJail
main/jails											9.06G   207G   336K  /main/jails
main/jails/.warden-template-pluginjail				1.24G   207G  1.23G  /main/jails/.warden-template-pluginjail
main/jails/plexmediaserver_1						  3.29G   207G  4.52G  /main/jails/plexmediaserver_1
main/jails/plexmediaserver_2						  4.52G   207G  5.75G  /main/jails/plexmediaserver_2
[root@freenas] ~#
